help - headlight switch
Old Jan 1, 2006 | 02:03 PM
harrin's Avatar
harrin
Default help - headlight switch
how do you get the switch from the dash pad, i have the pad off and the lever out, just need to get the switch from the pad, any help is appreciated.
Old Jan 1, 2006 | 03:30 PM
shafrs3's Avatar
shafrs3
There is a little trick to this and I don't remember the specifics, but the key to it is a little metal button on the switch body that enables you to remove the switch **** and shaft from the switch body. If you press this button down and pull out the **** and rotate it, the **** and shaft will slide out. Play with it some and you'll probably stumble onto the correct combinations of movements.
Old Jan 1, 2006 | 04:27 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
this is from an '80. On the bottom of the switch, just forward of the vacuum line connections is a small push button. While pushing it in, you pull the switch out.
Old Jan 1, 2006 | 04:52 PM
harrin's Avatar
harrin
Thanks alot for your help!!
To help - headlight switch
