side yokes
Old Jan 1, 2006 | 11:17 PM
gator79's Avatar
gator79
Default side yokes
what is the maximum play in the side yokes? I have 71 big block?
Old Jan 1, 2006 | 11:27 PM
big_G's Avatar
big_G
No published spec, but anything more than 1/16 inch needs looking at.
Old Jan 1, 2006 | 11:30 PM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
Gary wrote specs here:
yoke specs
Jim
Old Jan 2, 2006 | 11:59 AM
GTR1999's Avatar
GTR1999
Hi guys I want to point out that there has never been a published spec on yoke endplay that I know of.
When asked about this I inquire if the diff is in the car or out. If in the car and there is no other reason to work on it, then under .030 is ok. If you have more then .050" I'd consider replacing them.
The snap ring groove is .187 from the end. Typically these were case hardened which is about .030" deep.
Also when you reach .100+ of wear the powdered metal ends up in the oil, it will not turn it into a paste but it's not good for the bearings either. If you have that much wear I'd rebuild it and do it right,but that's a lot more money then just replacing the yokes so you have to decide what you want to do with the car.
Good luck
Gary
To side yokes
