1978 corvette needs to be lowered
Old Jan 2, 2006 | 10:36 PM
norcalboi's Avatar
norcalboi
Default 1978 corvette needs to be lowered
Does anyone know the most practical way to lower a c3around 2"
Old Jan 2, 2006 | 10:59 PM
big_G's Avatar
big_G
Vette Brakes and Products street/slalom springs and 8 inch rear spring bolts. (Or cut your front springs down a little at a time.)
Old Jan 3, 2006 | 02:37 AM
enkeivette's Avatar
enkeivette
& VBP 550lb springs for the front. They lowered mine about 1" You can cut half a coil or so if you want more of a drop.
After junking over 100lbs from my front end, I need to cut my springs to get me back down to where I was.
Old Jan 3, 2006 | 09:45 AM
rihwoods's Avatar
rihwoods
This mine after cutting stock FE7 coils...we only cut half a coil...
245-60-15 Yoko's on it now...but no problem with 255-60-15's...
http://www.corvettesoftv.com/images/woods78.jpg
Oh...rear tire worn cause alignment was off....
Old Jan 3, 2006 | 12:16 PM
lowbuck72's Avatar
lowbuck72
Cut one coil...
Old Jan 3, 2006 | 01:44 PM
panic's Avatar
panic
Originally Posted by lowbuck72
Cut one coil...
lowbuck i like the color of your car...it's very badass
Old Jan 3, 2006 | 02:16 PM
holley505's Avatar
holley505
mine has 1.5 coils cut out of it....
but I have a LIGHT MOTOR....
LS1
Old Jan 7, 2006 | 11:50 AM
norcalboi's Avatar
norcalboi
thanks for the info ill get right on it
Old Apr 2, 2006 | 03:20 AM
cherrybomb78's Avatar
cherrybomb78
Does anyone know if you can use a rear spring bolt longer than 8" to lower the rear end? Lets say a pair of 10" bolts?? I dont like the jacked up look of the rear end. I am using the 8" bolts now and have 9 leaf stock springs and it's aprox. 2" higher than i'd like.
Old Apr 2, 2006 | 03:35 AM
TonySinclair's Avatar
TonySinclair
When you go to 10" bolts, you run the risk of the bolt hitting the sidewall.
Get a different spring...
Old Apr 2, 2006 | 04:42 AM
wnjlt1's Avatar
wnjlt1
550's and (1) coil removed for the front and a shortened rear spring with 10" bolts to bring her down at the rear
Old Apr 5, 2006 | 03:25 PM
cherrybomb78
what do you mean by "shorten" the rear spring? shorten the arch?
To 1978 corvette needs to be lowered
