295/65/15 tire...
Old Jan 3, 2006 | 01:39 PM
panic's Avatar
panic
Default 295/65/15 tire...
hi, just a small info request, will a 295/65/15 tire fit into a 8X15 wheel? and will this set fit under my '77 vette without offset trailing arms not shorther guldstrand composite rear spring? thanks..
Old Jan 3, 2006 | 01:50 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Might as well get a pair for the front and go for the full 4X4 look
That tire is going to be a way to tall in my opinion, will it fit, probably
Old Jan 3, 2006 | 01:57 PM
SteveG75's Avatar
SteveG75
295/65/15 equals a diameter of 30". Stock is right at 27".
You are going to have major fit problems with that tire.
Old Jan 3, 2006 | 02:40 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
better look at 295-50-15 tires, that's what i'm going to put on the rear with my stock aluminum rims... I think it was Motorhead who posted a photo of this combination not too long ago - it looks .... hmmm.... huge .... wide..... biga$$ tire......
Old Jan 3, 2006 | 04:46 PM
flood's Avatar
flood
Wont that size stick out past the fender?
Old Jan 3, 2006 | 08:32 PM
CrossedFlags77's Avatar
CrossedFlags77
I had 295/50/15's on 10" wide wheels. They stuck out about an inch from the fender. I ditched that and went with 15x8's with 275/60/15s and they look alot better.
Old Jan 4, 2006 | 02:57 PM
Jims79's Avatar
Jims79
NO 275/60/15 is the widest tire that will Safely fit on a 15x8 rim. You will need to go to a 15x10 for that tire. Did you ever see a 275/60 on the rear of a vette that's a lot of rubber. What are you thinking 295/65
Old Jan 4, 2006 | 06:34 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
The overviews on tirerack.com say the recommended rim size for 295-50-15 is 8-11 or so.... not sure if it was 10 or 11 but 8" is listed as the minimum for this tire.
Old Jan 4, 2006 | 07:57 PM
66CorvetteCoupe's Avatar
66CorvetteCoupe
Default 295 / 65 / 15
Wow that's a big tire. The specs on that tire say approx 29.5 inches tall but fully inflated those things are closer to 31". I ran a set on my 79 Camaro Street/Strip car I had major problems making them work there. My guess is no way on a Vette without major mods. That's my 2-cents.
Old Jan 5, 2006 | 01:11 AM
panic's Avatar
panic
well, i have the 275/60/15 in the rear of my '77 but i've seen a very nice 295/65/15 white rised letters (i've forgotten what brand but it was a race rubber) and i thought it would look veeeryy badass
Old Jan 6, 2006 | 03:20 AM
Zimo's Avatar
Zimo
Here's a few pics of 295-50's on another forum member's car...Can't remember who
Big pic: http://img380.imageshack.us/img380/6...es295507ot.jpg
Big pic: http://img468.imageshack.us/img468/2091/tires27jq.jpg
Big pic: http://img222.imageshack.us/img222/9858/tires36bm.jpg
To 295/65/15 tire...
