Help - Tacho light went out !
Encountered my first problem with the 78,
While I was driving at night the tacho back light just went out, (its a pain to drive when you cant see the RPM's) and when I indicate right the green arrow does not flash. All the other lights work fine on the instrument panel and on the outside of the car. How do you change the light globe in the instrument cluster if it has blown ? Perhaps a lose wire or connection ?
Anyone else have this happen to them ?
Appreciate any suggestions as to what to check first ?
Thanks.
Ciao Giuseppe.
Sounds like the earth for the tach has gone missing.That's why none of the bulbs work. Means looking behind the instruments for a loose ground wire.
By the look of it the car has not been converted to RHD so at least it may easier to fix than one with a conversion.
How about reducing the size of the pic in your sig so it doesn't take all day to load?
Regards,
The two bottom ones on the spedo dont light up either, only the top two.
Boy its hard to look at where the wires go behind the dash, there is just no room to look ?
Doesn't the 78 have newer dash with the flexible circuit board that runs to all the lamps? The fact that you lost half the lamps all at the same time may indicate that one of those flexible traces went open. If you lost the ground, would you lose all the lamps and the tach?
Ok guys ... I took the 78 out last night for the first time with the t-tops off, cruised past the beach with my buddy, woo did we attract some attention
Anyways, I know the globs are defiantly not blown behind the tacho, I went over a bump in the road, and they came on and worked for about a minute, then disappeared again. ?
The Right indicator green light will still not flash
My car is a 4 speed by the way, so no cruise control.
However I guess its still the same process of disconnecting the Speedo cable to pull the whole instrument panel out, perhaps its something to do with the flexible circuit board ?
I wonder how much this is going to cost to fix ?
HAHA ... one can only laugh, and whip out the credit card with these muscle cars !
Mine does the same thing...I go push the right-front side-marker bulb back into place and ....VIOLA! all is good again.
Every month or so the bulb loosens in its socket and needs to be pushed in.
That indicator light staying on and not flashing is a sign that there is a break in the circuit.
If not there...check the indicator bulb and socket behind the dash.
Unscrew, clean and check all your bulbs and corrosponding sockets before you deem the P/C board bad and purchase a new one.
On these old cars; the "bulb and socket check" is preventative maintenance...lol
BTW--this is a "free fix".
Jim
