Car overheats at speed
Old Aug 4, 2001 | 12:30 AM
LT1driver's Avatar
LT1driver
Default Car overheats at speed
Car has small hipo motor, runs cool with airco on in town all day long, but at 65 + in runs right up to redzone or 250 degrees. It has new clutch fan. Car is high mileage with over 200K on motor. Ideas? Thanks.
Old Aug 4, 2001 | 01:05 AM
BubbaJJ's Avatar
BubbaJJ
Default Re: Car overheats at speed (LT1driver)
Mine was doing the exact same thing. I had the radiator rodded, a high volume water pump, removed thermostat, nothing helped. I dont know why but the only thing that fixed it was an aluminum radiator.
Old Aug 4, 2001 | 01:16 AM
Jvette73's Avatar
Jvette73
I had a car that did this once before. I tried everything in the book to solve the problem except rodding the rad. Most likely the radiator tubes are plugged internally. Also could be excessive debris and bugs and whatnot clogging the rad fins, not allowing the air to pass thru the rad. Drain a small amount of coolant from the rad and look down into the cap opening with a flaslight. If you see lots of crud and build up comming out of the tubes its probably time to pull it and send it in for a rodding or a new core. You might find that a new rad is a better choice.
Old Aug 4, 2001 | 03:48 AM
lou's Avatar
lou
Default Re: Car overheats at speed (Jvette73)
A new radiator and water pump would be a good place to start. lou
Old Aug 4, 2001 | 04:23 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Car overheats at speed (lou)
Is the front air dam in place? Are the seals in place around the radiator and shroud? Overheating at speed could be caused by these items. Chuck
Old Aug 4, 2001 | 07:16 AM
mrvette's Avatar
mrvette
I did all of the above suggestions but on my '72, the cure was removing the front tag and frame...revealing the egg crate grill in the center....
that increased front airflow about 30%....problem solved....
of course in Md. youneed go illegal without a front tag, but it's a minor offense and not likely to be noticed....I drove a '70 Lemans/GTO like that for years up there....
GENE
Old Aug 4, 2001 | 07:51 AM
The Wanderer's Avatar
The Wanderer
Default Re: Car overheats at speed (mrvette)
I'm with Chuck on this one. If it doesn't overheat in traffic and low speeds, the basic cooling system must be in marginally good condition. At higher speeds all air must be directed through the radiator. You must have the lower air dam, and all radiator seals in place. Make sure the upper one makes a complete seal with your hood.
Good luck and keep us informed.
Old Aug 4, 2001 | 07:46 PM
GDaina's Avatar
GDaina
Default Re: Car overheats at speed (The Wanderer)
End of june I got the 533 running. Putzing around town it was fine, on the open highway it shot up to a steady 230.
Problem was the cooling fins, on the bottom part of the radiator, had seperated from the core. Got a new core, dual fans, was running below 180, I put back the front license frame bracket and plate. Now it runs a steady 180. :cheers:
Old Aug 4, 2001 | 10:19 PM
LT1driver's Avatar
LT1driver
Default Re: Car overheats at speed (GDaina)
Thanks for the comments, I will try the radiator first since the water pump was changed not to long ago, I will let you know what works. Thanks.
Mike
Old Aug 4, 2001 | 10:37 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Also be sure the "spring" is in the bottom rad hose, without it the hose can collapse at speed.........
Old Aug 9, 2001 | 01:28 AM
LT1driver's Avatar
LT1driver
Default Re: Car overheats at speed (yellow 72)
Thanks all, I changed the lower hose and the problem seems to have been solved. I will take a 3 hour trip this weekend to confirm. Thanks again. :D
To Car overheats at speed
