Tachometer Issue
Tachometer works but idles at 5500 rpm. When you rev the engine the needle runs the opposite direction
(counterclockwise). I have heard mentioned a filter and or a Circut as possible cures. Has anyone had this issue and what course should I take.
(My tach didn't work either and I had to fix it.)
There has been some discussion as to the purpose of the filter.
My belief is that the tach filter was put in to reduce the 'noise' entering the cockpit. This noise was probably being picked up by the radio resulting in a whine on the speakers.
It does not offer much additional protection from high voltage spikes. The circuit board on the back of the dash already has a filter on its input which should provide adequate protection against that.
The Tach filter can be replaced with an RC network to see if it has any effect. This can be done easily without paying $30 for a filter. A schematic of the tach filter can be found in some previous posts. I have it somewhere and could send it if needed. Exact values are not that critical, and I think you could achieve the same thing with a 10K ohm resistor followed by a .1uF cap.
However, the symptoms you describe are kind of wierd. I can't imagine how a defective tach filter would make the tach run backwards. A defective filter usually means a wire has vibrated loose and no pulse gets to the instrument panel. That would make it read 0 RPM. My bet is that the board on the back of the instrument panel is blown.
You could have a bad ground, but I think the odds of that are kind of slim.
Not working how?
If the tach board is functioning, but the tach signal isn't getting up to the dashboard, then it should go to 0 RPM when the ignition key is turned to run. No signal - 0 RPM
If the tach is pegged at some other value (Say 3000 RPM)
then its probably your board. Watch it carefully, if it moves even little but pegs at some odd value, then its probably the board.
If the tach does nothing (no movement at all!), then it could be power.
Repair? Anything that one man made, another can repair. However, the success rate by those who are not versed in electronics is extremely low. Parts are obsolete and hard to find. Your better off buying a new board.
Good Luck
Bill.
(counterclockwise). I have heard mentioned a filter and or a Circut as possible cures. Has anyone had this issue and what course should I take.The Best of Corvette for Corvette Enthusiasts
What the heck - Corvette Clocks by Roger is where I got the tach assembly including circuit board that worked perfectly. The faulty circuit board was purchased from Mid-America.
Any suggestions of who is the most reliable to purchase from?
