which pulley groove
Old Jan 5, 2006 | 05:52 PM
painterman52's Avatar
painterman52
Default which pulley groove
I`ve been having trouble with alternater brackets on my 75. Broke 2 upper, they were aftermarket chrome, I put the correct one on. Now my lower bracket snapped. The belt is in the pulley closest to the engine. The power steering belt is in front. Is this correct. Any reason I would be having this much trouble or is it just bad luck?
Old Jan 5, 2006 | 08:51 PM
David Ey's Avatar
David Ey
Thats where they are on my 78.....outside=ps...middle=ac...inside=a lt
Old Jan 5, 2006 | 09:48 PM
kona's Avatar
kona
Just came in from the shop and the alt belt is the closet to the block then the a/c and the p/s is on the outside this is on an 80. I just bought a really nice alt bracket from Summit Racing that you might want to check out.
It is the adjustable type that uses a single rod to adjust the tension. Very heavy duty and comes in polished or chrome. My chrome one was $69.
Kona
Old Jan 5, 2006 | 10:20 PM
BigE's Avatar
BigE
Here are the pulleys on my 75... alternator in back, PS in front. Hope it helps
[IMG][/IMG]
Old Jan 5, 2006 | 10:22 PM
isosceles's Avatar
isosceles
sounds like REALLY bad luck. I can't see how those should break before the belt would.
To which pulley groove
