Shorty headers?
Yes---right to the stock exhaust system...you will have to cut-to-fit to the existing exhaust some...how much?... hard to say without measuring.
Take a few measuements.
Outside header flange boltholes to bottom of collectors bolted in place...then inside bolt holes to same...make a rudementary sketch on paper (you should end up with a wide "V" and a skinny "V"...
then do the same to your stock exhaust manifolds.
compare sketches.
That will give you and idea of how much of your pre-existing exhaust pipe you will need to shorten.
You are going to have to cut your pre-existing pipe anyway to remove the "flare" that seals the existing pipes at the stock manifolds.
Once measurements are compared you will know how much *extra* that Hedman collector has...and go from there.
you cannot just remove your stock manifold and bolt right into place...two cuts will be necessary no matter what.
Whats with the silver mini-headers?
Jim
ps.
if the measurents I am describing is confusing...when I get back I will draw a sketch and scan if for you, to get an idea before you start unbolting things...if its the correct application for your car, the sketch will give you a very good idea...those collectors appear to have 2 to 3inches of room for slight cutting errors..but even if cut too short, a flanged add-on is easily done.
Don't go to the trouble of a sketch...this is just a fact finding mission for now...nothing will happen until spring....maybe I can tap ya for a sketch then if I decide it's a go....OK?
I think I am trying to figure if it's going to do me any good putting them on or would it be just cosmetic????
Bill
Again, are the shortys a performance help or just cosmetic?
), the trouble of the swap doesn't seem worth it, but the look of black headers, even shortys might be worth it...that's why I'm asking questions...rather torn
Thanks..
