What is the purpose of having these holes above the cam bearing tapped and plugged on a 400 SB? When I get my block machined...should I have the shop do this???
Eddie
Those are the main oil galleys. The main reason to have them drilled and tapped for pipe plugs is insurance. Normally you would stick a pressed(more like hammered in) plug simillar to a freeze plug. Now say you have these pressed in plugs and you stick in a high volume, HIGH pressure oil pump and your good old boy machinist forgot his loctite that day and was a little tippsy from the night before and he wasn't totally level with the world and one of those hammered in plugs was a little cooked and not tight in the hole. Few days on the road and bam, there goes your oil pressure and well your engine.
Put in the pipe plugs, it doesn't cost that much and its good insurance. Aslo when you get your block back and your cleaning everything with a tooth brush, pipe cleaners and hot soap and water you'll be able to take those plugs in and out to clean up those main galleys.
Be careful when you put them back in that you don't block the first cam bearings oil hole. that would eat up that cam bearing quick if you block its oil passage.
Eddie
to keep the plugs from coming loose is the reason they are tapped
you can do this if you can usa a tap
and the small holes provide oil to the back of the cam gear
Thanks for the replies guys. Maybe I didn't word my question properly. You all graciously answered why they are tapped for screw in plugs. (instead of press fit plugs) I'd like to know why are these holes plugged? Does plugging them re-direct oil flow? What happens if I DON'T plug them?
Thanks for all the replies
Eddie
If they are not plugged you will have no oil pressure. The block was drilled or cast with the oil passages running through the block so that the lifters would oil (under pressure), but you just can't leave that big of a hole in the oil passages and expect to have any oil pressure.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
They are in the back too, that is where you put oil restrictors if so desired, I have them in my 406 to restrict flow to the upper valve train and keep more oil around my solid roller. Seems to be working my lifters look brand new after 10,000 miles
my builder called me a few weeks back about how the last builder had the holes so too much oil went thru threaded plug ,,he must have been talking about this he said he was plugging them up and getting the engine oil to flow from another part,,i think this is what he was talking about and how guys build motors with too much oil in there,,he said my old build was a big oil pump,,
The holes have to be there for casting, where else is the sand going to go? It's the same if the holes are drilled in the rough casting, you can't drill without leaving a hole. Having the hole going through both ends gives the factory a visual check that the galley holes are drilled in the correct spot. Then they get plug so the system will pressure up.
