Transmission Line Question
Old Jan 8, 2006 | 12:16 PM
82Powerhouse's Avatar
82Powerhouse
Default Transmission Line Question
1982 Corvette
350 CID
TCI 371000 Transmission
I had to cut my transmission lines that were on my old 700R4, and I was wondering if I could put rubber from the tranny to the original steel lines. I did not want to have to replace the entire line if I did not have to. I found some brake line, but the tubing hole is slightly smaller in diameter than the original. Any advice on this would appreciated.
TIA,
CDM
Old Jan 8, 2006 | 12:22 PM
ltlevil's Avatar
ltlevil
A piece of fuel line will work without any problems.
ltlevil
Old Jan 8, 2006 | 03:14 PM
fl_rider's Avatar
fl_rider
ltlevil
DONT USE FUEL LINE !!!
It will break down.
There is hose specifically for ATF.
Old Jan 8, 2006 | 03:34 PM
big_G's Avatar
big_G
Buy transmissiom rubber line, 5/16 inch, I believe.
Old Jan 8, 2006 | 04:01 PM
ltlevil's Avatar
ltlevil
It will break down.
While there is ATF line I know from expierience that you can use fuel line. Now this is personal expierience maybe everyone's situation is different, what makes you say the fuel line won't work? Don't take me wrong I'm not trying to be argumentitive but if there is something I can learn then good, but for the last 20 years or so if I had to splice a piece of trans line I have always used fuel line with no trouble.
ltlevil
Old Jan 8, 2006 | 04:09 PM
Vette Gator's Avatar
Vette Gator
I'm just passing on what I was told at a good parts store. Both ATF and fuel line have the same level of solvent resistance. The difference is that the ATF line also is heat resistant.
Old Jan 8, 2006 | 04:33 PM
82Powerhouse
Thanks for the advice. I will get the hose and not concern myself with getting the steel tubing.
Old Jan 8, 2006 | 07:07 PM
redc3's Avatar
redc3
i did this once on one of my first cars. the lines would pop at high acceleration. spilled fliud all over my girlfriends dads driveway. it can be done but i dont recommend it
Old Jan 8, 2006 | 07:31 PM
ltlevil's Avatar
ltlevil
The heat thing makes since, guess I been lucky.
ltlevil
Old Jan 8, 2006 | 08:02 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Try this: http://www.bowtieoverdrives.com/cata...AT&CATID=UA1A1
I've not heard anything about it, but it looks like a good system. Basically hard line to about where it connects to the radiator, then braided steel.
Old Jan 9, 2006 | 01:06 AM
Star79's Avatar
Star79
If you use rubber line, make sure it's the FUEL INJECTION kind. It's rated for 100+ psi, where the cheapo stuff might actually blow under tranny pump pressure.
I've got about 8 feet of this in my 79 (from trans all the way to my tranny cooler and back) and haven't had any problems in 3+ years.
To Transmission Line Question
