Master Cylinder overflow
Old Jan 8, 2006 | 07:46 PM
randyredleg's Avatar
randyredleg
Default Master Cylinder overflow
I have a little fluid coming out of the top of the master cylinder. It is not over-filled, and the lid seems to fit properly. Could this be a back-up because of air in the lines, or does it look like a problem with the master cylinder?
Old Jan 8, 2006 | 11:12 PM
redvetracr's Avatar
redvetracr
I had a similar problem, I removed the bails and placed them in a vice and ever so slightly tapped the center down, just enough to add some pressure when attached to the MC.
...redvetracr
Old Jan 9, 2006 | 01:55 AM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
did you recently replace the pads??
Old Jan 9, 2006 | 05:07 AM
Solid LT1's Avatar
Solid LT1
Could be from too much brake rotor runout also, the pads being knocked back by rotors will pump fluid into MC at igh pressures.
To Master Cylinder overflow
