Tachometer Circut Boards
Old Jan 9, 2006 | 11:08 PM
Boomer's 75 Vette's Avatar
Boomer's 75 Vette
Cruising
Default Tachometer Circut Boards
I earlier submitted a question on my tach issue, and the conclusion was that I needed a new circut board. Thanks for the Help.
Many have said to buy a good board and watch where you get it from. One individual even bought from a big Corvette Parts supplier and the board was bad. Where is a good place to get a circut board? I found this on E-Bay and was wondering if any one has purchased from him and would recommend. (I have a 1975 Corvette)
Tach Circut Board
Old Jan 10, 2006 | 01:23 AM
JOliver's Avatar
JOliver
Thats a great place to get one(from that seller anyways) He has the best boards on the market.
Old Jan 10, 2006 | 01:26 AM
Kilroy1024's Avatar
Kilroy1024
This name has come up before, but I can't seem to find it by searching.
I don't recall if the feedback was good or bad.
1) It looks like he's using the standard tach chip and recommended circuit.
(National LM1819 or equivelant)
If he's got the std chip and is following the data sheet,
then the worst he can do is solder joints.
2) Ask him if he copied the 75/76 circuit directly, or if he corrected the design problem that leads to the burnt spot.
(75/76 used a zener to protect against overvoltage,
problem is reverse battery will immediately burn out a trace!)
3) His troubleshooting information appears to be correct and from it,
I would say he knows what he's talking about.
4) If your board is an original 75/76 with a burnt trace, it might be repairable. Jumper the trace and replace the zener diode on the input.
EDIT: Out of curiosity, I asked Gardner my questions about his boards.
1) He uses the std chip.
2) He's updated the 75/76 boards to eliminate the common problem of the burnt trace.
Old Jan 10, 2006 | 01:38 PM
Boomer's 75 Vette
Cruising
Thanks Kilroy, I really appreciate your advise and help. Thanks for checking direct to the supplier.
Old Jan 10, 2006 | 02:15 PM
OldSchool's Avatar
OldSchool
Which Zener is the one to replace?
Old Jan 10, 2006 | 05:34 PM
bams12's Avatar
bams12
I bought a tach board from Ecklers to fix my burnt 80 board. The board from them did not cure my problem. Emailed them 2 times about the situation with no reply. My advise, buy from somewhere other than ecklers. Brent
Old Jan 10, 2006 | 06:00 PM
jdmick's Avatar
jdmick
Usually "Mike Mercury" here responds that he fixes them. Might want to PM him.
Old Jan 10, 2006 | 07:37 PM
comp's Avatar
comp
Old Jan 10, 2006 | 08:12 PM
Kilroy1024's Avatar
Kilroy1024
A picture of the board pulled out of my 76 can be found here:
http://members.shaw.ca/gvn/1976.html
No gaurantee that the board was the same for the whole year.
The zener is the black round component connected across + and -.
Datasheet specifies 18V/1W 2N2476 or equivelant.
As stated, Mike Mercury often has input to these threads.
He can repair and calibrate your tach if you don't want to tackle it yourself.
Getting the pointer off and cleaning the face can be a bit tricky.
Oh yeah, and I can't say this enough: DO NOT TOUCH THE FACE!
The ink can smear. If you want to clean it, use an air compressor.
Q-Tip smudges on the black areas can be cleaned with a Q-TIP.
Better yet, leave it.
I've been gathering tach info to post on a webpage,
Which I will get around to someday.......
Old Jan 11, 2006 | 12:19 AM
Jaxtoy's Avatar
Jaxtoy
Great guy to do buisness with, and his ckt boards work. When I got mine he offered a free replacement if it didn't work.
Nice to find replacement parts that work...great price also.
Old Jan 11, 2006 | 02:23 AM
JOliver's Avatar
JOliver
Yeah Where is Tim when you need him....I think he'll tell you that the above tach boards are the best on the market the componets are very good and the calibration is already done(make sure of it I think he does sell them "uncalibrated" but you don't want one).
The Ecklers boards are junk....not only do not work some have a really bad design on the back side that has metal linings for all three holes that the studs stick through...all three metal holes touch the metal coil.Most of you know that you can't have a signal,positive and a ground TOUCHING!.The gardner boards are the best.
BOOMER'S 75 Vette-email me about this I can help
Jason
VetteInstruments@aol.com
Old Jan 11, 2006 | 10:35 AM
Maymyvetteliveforevr's Avatar
Kilroy1024, You mentioned in one of your posts that 76 was the first year of the electronic tach. It was actually 75, since that was the first year of the HEI ignition.
Old Jan 11, 2006 | 03:56 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
To Tachometer Circut Boards
