81 vette front wheel
Old Jan 10, 2006 | 08:17 AM
bickel's Avatar
bickel
Default 81 vette front wheel
when I stop my vette the front passanger wheel move foward and back towards the front of the car not in and out what could be causing this? it also kinda makes a loud claping sound like clunk/clunk
Old Jan 10, 2006 | 08:49 AM
Bill Baird's Avatar
Bill Baird
While online diagnosis without ever seeing the car is difficult, the first two things that come to my mind are:
1) You could have either wheel bearing that's totally shot (and the wheel could come off).
2) The frame where the lower control arm connects to the frame could be cracking (which also could eventually completely give way, and end up with catastrophic carnage).
If either is true, I certainly wouldn't recommend driving the car much in that condition.
Old Jan 10, 2006 | 09:15 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Default also check...
This problem could aslo be attributed to worn ball joints. but either way this car should'nt be driven untill you get it on a lift and check it out....
How much travel are you talking about when the wheel moves/
be safe
Tim
Old Jan 10, 2006 | 09:19 AM
moosie982's Avatar
moosie982
Could be bad ball joints, upper control arm shaft or bushings, shims missing (fell out) It would not be advisable to drive it too much before you check it out, could be a bad experience for ya, Peace,,, Moosie
Old Jan 10, 2006 | 09:23 AM
Bill Baird's Avatar
Bill Baird
Good point. I've had shims fall out like that when I had my '75.
Old Jan 10, 2006 | 01:20 PM
bickel's Avatar
bickel
saw some shims fall, two three inch movement pretty sure bearing are shot ordering new hubs and spindles tonight what else should look at could not see anything obviously wrong when on the the lift kinda confused on this one but not driving it right now registered non op (in germany)
Old Jan 10, 2006 | 01:29 PM
sweethence's Avatar
sweethence
Weil Grusse,
Also look at the ball joints, do this by shaking the spindle while still assembled, you are loking for any side to side or front to rear movement. also examine th cross shaft on the upper control arm for wear on the bushings, and if you can determine where the shims came from remeber that fopr later ( do this by looking at the gap between the cross shatf and the frame. as far at the lower shaft goes, this mounts directly to the frame and should be solid and in place even if the busings are worn.
Soo. wo bist du im Deutchland. Ich habe gewhonst im Bad Kissengen, und auch kreis Framkfurt am mein.
Weil grusse.....
und Tschuss
Old Jan 10, 2006 | 01:43 PM
bickel's Avatar
bickel
I am in Wiesbaden Germany and will be sure to look at those items I hope and pray that there is nothing serious I am going to replace the bushins, spindle, wheel bearing by the end of january!
Old Jan 10, 2006 | 01:45 PM
sweethence's Avatar
sweethence
Weisbaden is a fun town. had some good times there and in Maiz and K-town... You in the service or Bist du ein deutcher?
Old Jan 11, 2006 | 04:13 AM
bickel's Avatar
bickel
in service
Old Jan 11, 2006 | 06:58 AM
sweethence's Avatar
sweethence
Default cool
cool, I was there for 4 years , and i really miss the free mostly use of the garage facilities. Good luck with the refit and keep us posted
tim
Old Jan 11, 2006 | 07:06 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
ball joints, bearings, cracked control arms or frame.. it could be any of those like the others said..i know it's prolly a given, but is the wheel on and torqued down tight? whatever you do, DONT DRIVE ANY FURTHER THAN ABSOLUTELY NECESSARY UNTIL YOU FIGURE IT OUT!
To 81 vette front wheel
