Following good advice of the forum yesterday to set up my Mighty Demon 750 on the 454.... I set initial timing at 18 degrees (vacuum advance plugged) at 1000 RPM. Ran the engine up to 2500 and only pulled another 10 degrees for a total of 28. I'm running an HEI distributor with stock weights and one light spring and one medium spring (advance mechanism is lubed and free). Shouldn't I be getting more advance by 2500 RPM? What's the recommended fix?
Never got around to tweaking the Demon......tonight
Check the distributor and see if there is a bushing on the limiting pin. These bushings can significantly limit the number of degrees of advance the distributor allows. I believe there are timing kits available for the HEI distributor that gives you a choice of bushings. You will have to find out which bushing works best by trial and error. As a check you might want to remove the current bushing you have and see how much advance you get without any limiting bushing. You may find that by dropping the initial a few degrees you are right on target without a bushing. Good luck.
I don't know, the distributor was set up on the bench while the motor was apart. Just ordered the advance kit and did the spring install according to recomendations on the forum (one light one medium). I didn't have time to switch to both lights last night, but I don't think that will give me another 7 degrees? Or will it?
As far as the bushings, I have a whole pile of those that came with the kit..was led to believe by historical forum posts that they really don't have much impact on overal advance so I left the "stock" one in.
I posted a thread about the springs last week, as I plan to do the spring change today....several replys said 2 light springs were too much and many, many said 1 light, 1 medium....I adjusted to 36* per the "Lars papers" back in the fall and am full in roughly 2500-2800 stock springs...I expect to be full in around 2000 with the new set (Lt/Med), but I guess we'll see...might want to adjust to 36* with your stock springs to get a base reading then go for the new springs...just my 2 cents....
Good Luck
check for max advance at 3500 that way you know that it is all in. Some stock ignitions have pretty high rpm total advances.
I've run high performance motors with 3000 or 3200 before all the mech. is in. The reason being that I had such high DCR and modern high swirl fast burn technology heads that make max power at @ 32 degrees of total advance. I'm now using the MSD dist. That i have 100 choices of total advance and advance curves. All set with switch positions. No moving parts.
Lower compression motors can use lower rpm total advance. Because EGR and lower compression motors have a high amount of residual exhaust gas left in the cylinder. Which in turn retards the flame travel requiring 38+ degrees of total advance to run right
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
hows that working for you???? i need a distributor for my l48 thats going in the hot rod and i am waffling between a $69 ebay HEI "specail " and a nice MSD one lile you have. this admittedly will be a "nothing special" motor perhaps the MSD unit would be overkill
You might have a curve that has a slight plateau at 2500 and then goes up again at 2700 or 3000. Especially if you are using 2 different spings. Pull the throttle back until you hit 3000 or 3500 just to make sure it is fully advanced. If it is and you are still only getting 10 degrees of advance, I would say that something is binding. As mentioned before, check to make sure the bushing is installed correctly. I have seen those installed upside down....
It's not cheap! I just went down to Summit and bought it along with Taylor pro wires and it's $500. But then you also have to have a coil. I use the Crane coil that is used in conjunction with my Crane digital multi spark HI-6R. So you end up with @ $850 dollars to fire your spark plugs. I also had to buy a new comp cams polymer gear for my billet cam because my shaft size was different from my previous Mallory Unilite dist.
IMO - It's a good idea to have an electronic dist. Just dial in your settings.
Put the light springs in last night and double checked the advance mechanism.....now I have 12 degrees mechanical for a total of 30 degrees at 3000...still not enough (?).
How much advance should the mechanical provide? Any suggestions?
take the all springs out and measure it....i would think it should be in the 16-22 range
Don't want to steal this thread, but while we're talking about it and you're a green lite, thought I'd ask...put a light and a medium in last Tuesday...I didn't put the lite on it, but seat of the pants "seems" better...how much of a noticable change should I expect, aside from actual timing light advance data??
Also, considering I have a DUI, Street/Strip HEI in there, and the old springs "looked" very light, will that make a difference?
Bob, I can do that, but what would cause the limiting factor now?
there would be no limiting factor except for broken parts, and the limits of how far the weights expand and you would only do this to see what the mechanical advance was....more of a test proceedure then anything.... you would not want to run the car with this because the advance would come in immediately but it will tell you what the most advance you can get out of the distributor is
when it is set up right it will be very noticable....it is the quick acceleration that you will notice the pull from say 1600-3000 rpm
OK...one more question and I'll let the originator get his thread back...is there any way to measure the spring tension...I must admit, the springs I took out looked very light and being a performance distributor, I am wondering if that recurve has already been done...with the lt./ medium new springs in, it "didn't" snap my neck, for sure...and can even lighter springs be had someplace?
you know the way to do this is put in springs that will give you the advance you want all in by 3000 rpm....Lars makes this so simple....just put lighter springs in until you get 36* by 2500-3000 rpm and don't worry about initial timing as long as the car starts ok...i'm using one light and one mdeium spring...the real key is to make sure the distributor is shimmed correctly and the mechanical advance shaft rotates fully and the bushings are all in place.
