Brake pedal assembly removal
Old Jan 11, 2006 | 10:35 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Default Brake pedal assembly removal
I pulled my dash as most of you know, and Still have problems
with getting to bolts and all the stupid wiring thats driving me
crazy. I see 4 nuts that look to be holding the bracket. They
hold the brake booster in place also. Are there more that I can't see?
I removed all 4, and it's still tight in there
I already bought my clutch and brake pedal assembly, but left
it at the office. So i'm not sure on all the mounting points
Old Jan 11, 2006 | 10:46 PM
evalu8r's Avatar
evalu8r
There is a nut the holds the wire harness in place at the bottom left corner, once you pull that off there is one more nut holding the booster. Other than that it should pull off. Don't forget the bolts in the windshield wiper tray that holds the upper brackets in.
Chris
Old Jan 11, 2006 | 10:54 PM
MEGALADON's Avatar
MEGALADON
Chris
Yea I got that one to. SORRY, make that 5 nuts.
Old Jan 11, 2006 | 10:56 PM
evalu8r's Avatar
evalu8r
That's it, you'll just have to pry it off carefully.
Chris
MEGALADON's Avatar
MEGALADON
Chris
Diden't know bout that. Where do I unbolt from ?
the wiper tray area, or underneath the dash?
and How many am I looking for.
Old Jan 11, 2006 | 11:01 PM
evalu8r's Avatar
evalu8r
There is 4 and you get to them from the outside.
Chris
Old Jan 11, 2006 | 11:09 PM
MEGALADON's Avatar
MEGALADON
thanks, I'll be back in 15 minutes
Wait, so thats 4 inside and 4 outside?
Old Jan 11, 2006 | 11:46 PM
JonnHeather's Avatar
JonnHeather
Correct. The 4 in the wiper tray are on the vertical piece directly above the bracket...
Old Jan 11, 2006 | 11:48 PM
MEGALADON's Avatar
MEGALADON
I'll be back
Old Jan 12, 2006 | 10:31 AM
evalu8r's Avatar
evalu8r
Sorry, had to crash. You should be done by now.
Chris
Old Jan 12, 2006 | 10:49 AM
BerniesVette's Avatar
BerniesVette
There were two more behind the speedo and tach guages that have to be removed too.
Bernie
Old Jan 12, 2006 | 01:07 PM
evalu8r's Avatar
evalu8r
Yep
Old Jan 12, 2006 | 01:49 PM
MEGALADON's Avatar
MEGALADON
Bernie
EVALUA8R, I crashed to, nothing got done.
SO, 4 for the booster, 4 in the cowl, and 2 more bolts for a tottal
of 10 ?
I'm here at work now, so I took some pic's, I only count 8 bolts
and all are in the inside.
Looks like 4 in the rear(BOOSTER) and 4 in front.
Old Jan 12, 2006 | 02:07 PM
norvalwilhelm's Avatar
norvalwilhelm
There are 10 bolts holding the assembly on. 4 are located in the windshield wiper trough, 4 for the brakes and 2 on the bracket above the steering wheel. 10 in total
Old Jan 12, 2006 | 02:18 PM
enkeivette's Avatar
enkeivette
You realize that the brake booster must be pulled out of the car right? That's what the four studs are attached to.
Old Jan 12, 2006 | 02:23 PM
MEGALADON's Avatar
MEGALADON
Yea, I knew that already. I have to pull the colum to make things easier
anyway. I would shoot myself to try and install DYNAMAT with the colum still there
Old Jan 12, 2006 | 02:27 PM
James B's Avatar
James B
When I did mine I did not have to pull the booster out of the car, I dont remember how it came out. I just asume that once the 4 bolts were loosened from the wiper compartment i was able to just slide it down and off of the studs. Maybe the booster studs moved enough for me to get it out. But I know I did not remove it from the car.
James
To Brake pedal assembly removal
Old Jan 12, 2006 | 02:30 PM
MEGALADON's Avatar
MEGALADON
James
James, you are right, you do not have to pull it completely out.
the bracket will slide off the studs.
Old Jan 12, 2006 | 05:55 PM
evalu8r's Avatar
evalu8r
I took my booster all the way off so I could clean and repaint.
Chris
Old Jan 12, 2006 | 06:38 PM
BerniesVette
I found that removing all three brackets under the dash really gave me more room to work. But if you can get the pedals swapped by removing only the bracket that holds the steering column up and the pedal bracket, then I see no reason to do more. I also removed the power brake booster as it just about falls out anyway, and it made it easier for me to replace the rag joint while I was working in that area too. Good luck with your swap. I hope it goes as smooth as mine has but a lot faster!
Bernie
