Which External FI Pump?
Old Jan 12, 2006 | 10:34 AM
Stumpdeisel's Avatar
Stumpdeisel
Default Which External FI Pump?
I found a guy with both the Vortex (or paxton?) T-Rex pump, and the Aeromotive 1000HP pumps for sale. Both are for a good price, with the aeromotive being $85 more.
Both will supply more than enough fuel, and the aeromotive is actually overkill, but if the pump is head and shoulders above the T-RexI'll spend the money, but I'm not familiar with it.
Looking for recommendations, thanks as usual for all the input.
SD
Old Jan 12, 2006 | 11:43 AM
Paul @ Thunder's Avatar
Paul @ Thunder
I've never used a T-Rex pump but I know they are a pretty good pump but noisey from what I've heard. We've used many of the Aeromotive A1000 pumps with very good results but it's gonna make a little noise too.
Old Jan 12, 2006 | 03:20 PM
70 LS1's Avatar
70 LS1
The Vortech pump is basically a Walbro 340 inline pump. 255LPH. A lot of LS1 conversion guys are using them. You can hear it when the car is off and the pump is running. You can also hear it when you are within 5 feet or so of the car when running. You can't hear it in the car when running.
Here is mine.
Old Jan 12, 2006 | 04:02 PM
Stumpdeisel
Cool, thanks all. Jeff, is that a stock tank with the return line running up to the top?
I'm leaning towards the aeromotive. It's supposedly a bit quieter, mounting tabs are built in to the unit, and I'll never have to worry about flow if I get the chance to add a blower down the road...
Old Jan 12, 2006 | 04:21 PM
70 LS1's Avatar
70 LS1
Sounds good. I have the stock 1970 tank with the return up top.
Old Jan 13, 2006 | 12:49 AM
Z-man's Avatar
Z-man
I went with the Aeromotive. The only time I can hear it is in the 3 seconds after key-on...
To Which External FI Pump?
