69 BB rebuild 430HP?????????
You really need to go to book store and get a book on building big block Chevy's. All the advice in the world won't do you any good if you don't understand what they are talking about.
When you talking roller cams your cost is going to be $1500 and up. A settup like mine is @ $2000 just in parts.
Even though its 1500.00 its cheap insurance.
http://www.cnc-motorsports.com/produ...Group2868=4876
Here is a conservative estimate of what can be done with a SB...
Ya, the $630 only gets you cam and lifters. How about matching quality timing set, roller timing cover, pushrods, quality roller rockers, springs, stud girdle, nice retainers
Here is a little list that I've got going with what I've ordered so far for mine. This is what I think a rebuild should look like..
AFR 195 68cc Straight plug heads p/n AFR-1034 w/ 7/16 studs p/n 6411 w/ springs p/n 8032 $1269.00
Comp Cams XR270HR CL kit CL12-422-8 635.00
Pro Magnum 7/16 1.5 rockers p/n 1304-16 $270.00
Eagle ESP H-beam rods p/n CRS5700B3D $335.00
SRP Forged flat top pistons p/n SRP-138082 $451.00
Clevite 77 Small journal std mains bearings p/n 695-MS429P $34.99
Clevite 77 Large journal std rods bearings 695-CB758P30 $47.99
JE Piston rings 1/16, 1/16, 3/16 plasma moly std tension p/n S100S8-4040-5
Centerforce flywheel p/n 183-700100
standard GM 1-1/8 dia x 26 spline input shaft then the number is 183-CFT361675 for the pressure plate and 183-384161 for the disk.
Head Bolt Kit 070-134-3601 49.99
Motor Mount Bolts 070-130-3102 8.99
Oil Pump Stud 070-230-7001 4.99
Fuel Pump Pushrod 070-134-8701 14.99
Motor Mounts (2) 355-3-1114G 59.98
Timing Cover 555-50306 29.99
Balancer 388-670100 159.99
Pointer 555-51263 24.99
Dura Bond Cam Bearings DUR-CHP-8 19.88
Oil Pan Stock Milodon MIL-3700 75.88
Oil Pump Baffle Moroso MOR-23000 4.95
Oil Pump Melling Standard MEL-M55 16.88
Oil Pump Drive Shaft ARP-134-7901 13.88
Balancer Bolt ARP-134-2501 18.88
Flywheel Bolts ARP-134-2802 9.88
Pressure Plate Bolts ARP-134-2201 9.95
220-9-3100A Adjustable Timing Set 99.99
249-4605 Comp Cams Lock Plate 5.99
249-200 Comp Cams Roller Cam Button 9.99
312-P4286829 Plastigauge 7.99
070-134-5501 ARP Main Studs 49.99
249-152 Comp Cams Assembly Lube 6.99
Roller cams don't have trouble breaking in, they have trouble living a long life. You have to pay close attention to them.
I'm talking solid roller here...not hyd rollers. Hyd rollers typically aren't going to rev to where a 427 will wont to go.
But a nice set of heads and a solid street roller will make LOTS of streetable HP....550-575 is possible without much effort.
JIM
JIM
I think there are some small details missing from the comparison between aftermarket roller cams and OEM roller cams. The biggest one is that OEM engines are designed for a roller cam. What's the big deal? As far as wear, it's the alignment between the roller lifter and the camshaft lobe. If the roller on the lifter is not parallel with the cam lobe, you are going to cause some wear. The OEM engines are designed with lifter retainers that have extremely tight tolerances for keeping the lifters inline with the cam. If the aftermarket conversions don't do the same thing, the end result will be people having wear issues and blaming it on the fact that they had a roller lifter.
As for the HP claims from the 60's, they aren't even close. I rebuilt my 390HP BB to basically factory specs (I have an HEI, roller rockers, and a few more degrees of duration). My engine makes right around 260HP breathing through the stock intake and 2" exhaust. I have confirmed this number with a chassis dyno (Mustang, not Dynojet), 1/4 mile time, and Desktop Dyno. The Desktop Dyno says I can gain 100HP with headers and mild port work.
I hear everyone saying the BB should be good for an easy 500HP, but I would also like to see some more detailed specs. This is the only engine I have built, so I would like to see some cam numbers and dyno sheets if possible. I wouldn't mind adding some HP to my car.
Ken
Ken
So the 260 hp is at the rear wheels? What is your 1/4 mile time.. trap speed actually, and race weight? Sounds like headers and exhaust would be your first and most cost effective step. I trap at 106 mph, and car is around 3550 lbs with me in it. I think that is just over 300 rwhp.
Flat tappet swap, sometimes you can use the same springs but I am going to count that anyway. Pushrods are almost always re-used. Timing cover is re- used. Rocker arms are ususally re-used SO:
Comp Cam : $100
Comp Cam lifters :$65
Comp Cam single springs : $60
Total : $225
Roller Setup, you need to go to full roller rockers, 0.80" wall pushrods is a good thing to be using, a timing cover that you can properly adjust endplay like the Cloyes 2 pc. adjustable is a wise thing to purchase.:
Comp Cams Hydraulic Roller cam and lifters $635
Pro Magnum Roller Rockers : $260
CC 0.80" wall pushrods : $110
Comp Cams double springs : $125
Cloyes timing set : $!00
Total $1230
There are many little things like valve stem caps, lighter retainers, 10 deg locks etc. that can easily put you into $1500 just like gkull says
Ken
