Engine Mounting Position on a Stand
Old Jan 14, 2006 | 09:56 AM
77Blue's Avatar
77Blue
Default Engine Mounting Position on a Stand
Is there an "optimum" mounting position on an engine stand with regards to balance ? I believe I usually see pictures where the mounting flange is approx perpendicular to the Cam. Also, I asssume I use the 2 lower holes on each side. Thanks in advance.
