help with parking lights
Old Jan 14, 2006 | 02:08 PM
spille85's Avatar
spille85
Default help with parking lights
Hey guys, I hope all is well with everyone. I need some help with my parking/tail lights. I noticed the other day when i position the light switch to position 1 (parking light position)...the parking lights and instrument lights do not come on. In position Two- the headlights flip open..but my parking and instrument lights do not work.any suggestions....maybe the switch or a possible fuse...i am not familiar with electrical on a vette. I have a 79 l-82 vette...any help would greatly be appreciated...
Old Jan 14, 2006 | 02:27 PM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
Originally Posted by spille85
Hey guys, I hope all is well with everyone. I need some help with my parking/tail lights. I noticed the other day when i turn my headlights on...the headlights work..but i dont have any rear lights or interior lights....any suggestions....maybe the switch or a possible fuse...i am not familiar with electrical on a vette. I have a 79 l-82 vette...any help would greatly be appreciated...
If you do a more extensive check and return here and write the symptoms you will be able to get more help.
Meaning:
Interior lights do work without headlights on..
but...
Position 1/(one pull of headlight switch)...lights X,X, and X work.
Position2/(two pulls of the headlight switch)...lights X, X, and X work...but; lights X,X, and X dont work.
If you have headlights and interior lights working at some point...you can almost rule out a fuse because the lights do work.
The tricky part is; do you have a short or a grounding problem...or jsut a switch shorting and ground because it is bad.
Also...check make sure all light bulbs and correctly installed into their sockets, and sockets correctly installed into thier lens.
Write on paper(if need be) and then post about it...your description is a little vague to pinpoint something at this moment.
Jim
Old Jan 14, 2006 | 02:48 PM
justkddn's Avatar
justkddn
start by checking fuse to tail lights,tail light fuse feeds tail light
and dash light fuse also.if fuse is blown then check for short.
short being a wire with insulation worn away,or pinched some where.
Old Jan 14, 2006 | 03:03 PM
spille85's Avatar
spille85
Default cant find tail light fuse
hey guys...where the heck is the position of the tail light fuse...i looked at the fuse panel and cant seem to find it..please help
Old Jan 14, 2006 | 03:10 PM
justkddn's Avatar
justkddn
on my 75 its just above the headlight dimmer
Old Jan 14, 2006 | 03:11 PM
justkddn's Avatar
justkddn
do you have a test light,if so it should be hot with the ignition off.thats both sides of the fuse
To help with parking lights
