HEI Distributor knocking
Old Jan 15, 2006 | 07:40 PM
enkeivette's Avatar
enkeivette
Default HEI Distributor knocking
My distributor makes a knocking noise. About 3 knocks per second at idle. It might be something else, but it sounds like it's coming from the distributor. What could this be?
I was in the middle of tuning my carb when this happened. After I heard the knocking, I drove it a few hundred feet and the acceleration felt rough. This could just be in my head, not sure.
I was going to wait till I had enough money to buy a Pro Billet HEI (last piece of the puzzle for the new motor) and pay for a dyno tune, but I'm getting fed up. I might just put it on my credit card and have it tuned on the dyno this week.
Old Jan 15, 2006 | 07:49 PM
marshrat99's Avatar
marshrat99
Pull off the cap and have a look inside. It might just be a broken spring or something else simple like that.
Old Jan 15, 2006 | 07:56 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Had the same problem on my 76. I had a worn bearing in the distributor. Changed distributors - runs a lot better now.
Old Jan 15, 2006 | 09:17 PM
TPL79's Avatar
TPL79
My HEI had a knock also. Turned out the shaft on which the weights swing had come loose.
Replaced w/a rebuilt HEI and problem no more.
Good luck.
Old Jan 16, 2006 | 10:12 AM
kevinator80's Avatar
kevinator80
Make sure the cap is seated properly. On two occasions my dist. knocked, first time I did not seat the cap straight; second time occured on the first start up after I wrecked the black car in my photos. Each time the engine fired and ran good but had a knock in the dist. cap.
Old Jan 16, 2006 | 12:53 PM
palazzopl's Avatar
palazzopl
I agree my cap wasn't seated right and I had the same knock repositioned the cap and the knock went away
Old Jan 18, 2006 | 12:53 AM
enkeivette's Avatar
enkeivette
Found the problem, can't believe I didn't notice it sooner. My steering coupler ripped off my number 5 spark plug wire.
To HEI Distributor knocking
