Edel vs Qjet
Old Jan 16, 2006 | 10:19 AM
Gage's Avatar
Gage
Default Edel vs Qjet
My 72 350 came with from the previous owner with edel 600cfm on there so I left it, but this weekend I got bored so I put the Q-jet back on there for the hell of it, and the car has more power it seems. Doesn't idle as smooth, but more power. I thought I would share for those are contemplating removing the Q-jet in favor of a edelbrock. The car is a L48 350 with a mild cam upgrade, 72 LT1 heads, edel intake, elect ign.,stock exh man with 69 sidepipes.
Old Jan 16, 2006 | 10:35 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
rebuild the qjet and it will idle just fine
Old Jan 16, 2006 | 11:23 AM
jackson's Avatar
jackson
Qjet is 750 cfm, edelbrock is 600. Qjet probably has smaller primary bores ... snappier throttle response ... Qjet definately has larger secondaries ... more power potential. IMO, a good Qjet is a better performing carb than a good edlebrock 600.
Old Jan 16, 2006 | 11:34 AM
JIMS1970VETTE's Avatar
JIMS1970VETTE
I have a 1971 coupe with a 350/270hp motor and it has a Eldebrock RPM intake and a Eldebrock carb and I was thinking of putting the Rochester on it but someone told me that the Q-jet wont fit because of the bore on the intake, square vs spread bore, and I haven't taken off the Eldebrock to look yet. Does that sound right?
Old Jan 16, 2006 | 11:49 AM
Gage's Avatar
Gage
It depends which intake you have...they have two different carb patterns, square and spread. The edlelbrock will fit on both, but the q-jet will only fit on spread pattern. Take your carb off and you'll be able to tell.
Old Jan 16, 2006 | 01:07 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Default wich edelbrock?
Which edelbrock carb are you talkign about? I have tyhe edelbrok Qjet replacement also at 750 cfm and i love it, ill rebuild the original later
tim
Old Jan 16, 2006 | 02:35 PM
Gage's Avatar
Gage
[QUOTE=sweethence]Which edelbrock carb are you talkign about? I have tyhe edelbrok Qjet replacement also at 750 cfm and i love it, ill rebuild the original later
No, I'm talking about the std sq bore edlel, not the q-jet clone. If I needed a q-jet I would get the one you have also.
Old Jan 16, 2006 | 02:55 PM
mrtroutjedi's Avatar
mrtroutjedi
tim
I have the qjet edelbrock 1903 it was one of the best things Ive done for the car
Old Jan 16, 2006 | 02:58 PM
jackson's Avatar
jackson
Which edelbrock carb are you talkign about? I have tyhe edelbrok Qjet replacement also at 750 cfm and i love it, ill rebuild the original later tim
Edelbrock 14xx series are squarebore clones of Carter AFB ... IMO, a good Qjet is better than a good EB 14xx.
Edelbrock 19xx series are spreadbore clones of Rochester Qjet ... and, sadly, EB no longer offers them.
Pretty sure Edelbrock RPM P/N 7101 is squarebore only ... Edelbrock RPM P/N 7104 fits both spreadbore and squarebore
Old Jan 17, 2006 | 02:17 AM
Kalway's Avatar
Kalway
Same here except mine is a 1904. I had to have it rebuilt right away because the knucklehead I bought it from misconfigured it horribly and I was clueless as to what was causing the problem.
If you can find an Edelbrock q-jet clone, they're excellent carburetors!
To Edel vs Qjet
