Engine Tech Discussion at Hooters Last Night
Old Jan 16, 2006 | 12:15 PM
Boofers's Avatar
Boofers
Default Engine Tech Discussion at Hooters Last Night
This is an exaggerated view of an engine cylinder wall after many miles.
Lets say this engine was babied all its life and was never revved above 3000RPM. Then one day the engine is revved up to 5000RPM. What result is more likely between these two possibilities:
1) As RPM increases the rod stretches and the piston ring probably shatters as it collides with the lip/ridge.
2) The piston ring does not shatter because there will probably be enough up and down wear for the rings to move in the piston ring grooves in the piston.
Your thoughts?
Old Jan 16, 2006 | 12:21 PM
big_G's Avatar
big_G
I say the rod won't stretch. If it does, you have bigger problems...lol
Old Jan 16, 2006 | 12:31 PM
proracr's Avatar
proracr
How can one discuss technical matters with all the "distractions" in Hooters?
Old Jan 16, 2006 | 12:34 PM
shafrs3's Avatar
shafrs3
neither option is likely(probable).
Old Jan 16, 2006 | 12:39 PM
Boofers's Avatar
Boofers
You get desensitized after a few hours
Old Jan 16, 2006 | 12:51 PM
proracr's Avatar
proracr
That explains it! When I go into Hooters, I have a meal and leave. I've never spent "hours" in there before.
Old Jan 16, 2006 | 01:02 PM
stingr69's Avatar
stingr69
So, let me get this straight....You are in Hooters, and you are debating the effects of cylinder wear on piston rings at high RPM....
I do not know the answer to that but I would like to hear more about the BEER. Vettes and the "quality" of the service.
-Mark.
Old Jan 16, 2006 | 01:06 PM
Tom454's Avatar
Tom454
"Performance builders recommend allowing from .002-.003 for rod stretch at high speeds. "
http://www.hastingsmfg.com/Service%2...ueprinting.htm
Old Jan 16, 2006 | 01:28 PM
Red 69's Avatar
Red 69
If you move from the theoretical and into the pactical, the engine will continue to run as those tolerances will not factor. Many years ago an old buddy had a 58 Buick Roadmaster that he was having problems with. Since he was going to junk it, he wanted to blow the engine. He put a cinder block on the acclerator at full throttle and we went inside for a cup of coffee. 30 minutes later it was still reving, but running hot. Eventually, it seized from overheating. If it could have been kept cool, with a steady supply of fuel, it might still be running. I think I read somewhere that GM engines need to be designed so that they will stand up to something like 30 hours of continuous full throttle action. I have beat on many well worn stock engines with no ill affect. I don't know how you could stay focused on this topic at Hooters without rod stretch coming into play.
Old Jan 16, 2006 | 01:37 PM
Boofers's Avatar
Boofers
You should try it! My local Hooters has a special program for thier patrons, if you buy enough beer in a set period of time you get a free cab ride home
Old Jan 16, 2006 | 01:38 PM
Boofers's Avatar
Boofers
Quality of service at my Hooters is good and bad. Lets just say that most of the Hooters girls are not employed for thier waitressing abilities
Old Jan 16, 2006 | 03:12 PM
kevinator80's Avatar
kevinator80
-Mark.
Hey Stingr69, if he were to go to a Hooters here in the south he would see why we don't talk about engines. His connecting rods would be the least of his worries.
Old Jan 16, 2006 | 03:42 PM
jackson's Avatar
jackson
Your thoughts?
Nothing will happen. (1) The cylinder taper will not be enough to have any effect on rod stretch at 5K. (2) There's plenty of room for the rings to move in-out ring grooves ... it's quite unlikely there'd be so much wear the rings would pop out of the grooves.
Old Jan 16, 2006 | 04:43 PM
Tom454's Avatar
Tom454
Point missed.
The rod stretch (also bearing failure) allows the top ring to contact the ridge at the top of the cylinder under high rpm, where grandma never ran the engine.
The day-to-day use created the ridge... at low rpm.
When the ring hits the ridge, the ring snaps in two, and tears up the cylinder walls.
I've pulled a lot of re-ringed engines apart that had broken rings in them. Bubba re-ringed 'em without removing the ridge, and then thought he had a "race engine".
So much for "practical" experience.
Old Jan 16, 2006 | 04:57 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i'd be bench racing the 36 cs against the 40 DDs.....what was your question again....give me another beer please....
Old Jan 16, 2006 | 04:58 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Old Jan 16, 2006 | 05:10 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
So that's where they have it, I'll have to go tell my wife.
To Engine Tech Discussion at Hooters Last Night
