Rebuilt Trailing Arm - no end play now
Old Jan 16, 2006 | 07:56 PM
ckerch's Avatar
ckerch
Default Rebuilt Trailing Arm - no end play now
Before pressing bearings on the spindal I used a setup tool and set endplay to .0018. I had light oil on bearings at that time. I greased the bearings and packed hub ,then reassembled . I do not feel any binding but when I go to check endplay I have none. Should the grease cause me problems rechecking endplay? I did hook up a drill and spin it a little but that did not help.
Carl
Old Jan 16, 2006 | 08:23 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Interesting,,,, I'm in the process of doing the same thing,, just made a set up tool at work today,, I do remember reading something about loosing or gaining on end play after packing the bearings,, serched for it without luck,, maybe somebody will explain this.....I'll be keeping an eye on your thread.......
Old Jan 16, 2006 | 08:41 PM
ckerch's Avatar
ckerch
I thought I heard that too. The only difference is I used a press to press on the bearings. I don't think I had applied excessive force on the bearings. Anyhow I would think the spacer would limit it.
Old Jan 16, 2006 | 08:45 PM
GTR1999's Avatar
GTR1999
The grease will stop the movement unless you really jump on it. If you correctly set the endplay to .0018" with spindle oil and the nut was torqued to 100 ft/lbs you should be ok. No need to use a drill, spin by hand it should be smooth,no binding.
I did one today too, the first shim I setup was .001" but I like to get a little more so i fit a new shim to .0015-.002" max. I spent more time dialing in the rotor on this one. Sometimes it's a 15 minute job to dial in others a lot longer. Final TRO was set at .002" with the flat head holding it so it should stay there regardless of the lug nuts.
Good job, have a beer and start the other one!!
Old Jan 16, 2006 | 09:09 PM
ckerch's Avatar
ckerch
Whew !! I thought I screwed something up. I did rotate it by hand and I don't have any binding , just stiffness from the grease. Thanks Gary for starting your rebuild thread and sharing your experence...It really helped.
Now on to the other side
Carl
Old Jan 16, 2006 | 09:13 PM
GTR1999's Avatar
GTR1999
No problem Carl thats why I hang here, to learn and help if I can.
Gary
Old Jan 16, 2006 | 09:20 PM
ckerch's Avatar
ckerch
Carl
Old Jan 17, 2006 | 08:25 AM
Tom454's Avatar
Tom454
One more thought to consider...
I started doing these bearings about 30 years ago with a 12 ton press.
A few years back, I purchased a 20 ton press.
I developed a "feel" for the 12 ton press such that I could tell when the bearings, spacer & shim stacked up. The first time I used the 20 ton press, I lost .0005 to .001 in bearing end play. Starting at .0015, it was now down to about .0005.. almost not measurable.
It was a lot easier for the 20 ton press to stack up the parts, and I over-did it, losing some endplay. That set of bearings is on my own C3... one at -0- endplay.
The 100 ft lbs of the nut is no competition for a 20 ton press.
You have to develop a "feel" for a press & know when to stop.
Even using the bearing setup tool has its quirks. After torqueing the nut to 100 ft lbs, the amount of pressure you exert on the end of the tool to get a dial indicator reading can cause a variance.
If you allow the spindle or tool to rotate even slightly while taking your dial indicator reading, you can get bogus numbers due to the unevenness of the tool and/or spindle. The assembly must remain perfectly stable when you take the reading.
You'd think it was a science, not an art.
If you approach a wall, and each step is one-half the previous step, will you ever reach the wall?
Old Jan 17, 2006 | 10:25 PM
ckerch's Avatar
ckerch
That's kind of what I thought might have happened. I might have went a little too far with the press (also have 20 ton press). I was relying too much on the shims to stop me, but .002 is not much distance.
When pressing on the inner bearing, it did not go as smooth as the outer. It was jerkier. I used a wooden block under the hub. Next time I will use a metal block and take baby steps. What I get from you and Gary, it looks like I can still use the one I completed.
Thanks for the input.
Carl
To Rebuilt Trailing Arm - no end play now
