engine warm up
Old Jan 16, 2006 | 09:35 PM
jrl1973vette's Avatar
jrl1973vette
Default engine warm up
hey probably a stupid ? but when you warm your cars up do you have to kick it down to make it idle lower after running a while or dose it kick down automatically and dose it usally idle high at first 73 L-48 carb was rebuilt full frame off just a ? thanks
Old Jan 16, 2006 | 09:42 PM
fl_rider's Avatar
fl_rider
Default Mine will idle down eventually...
but if I "HELP" it it occurs sooner.
Here in Burlington Wisconsin the choke REALLY works, as you have also found in Waukesha.
Hi neighbor!!
Chris B
Old Jan 16, 2006 | 09:47 PM
marshrat99's Avatar
marshrat99
Your carb is initially set on a hi-idle cam when you set your choke by depressing the throttle on a cold engine. Bumping the throttle will allow the carb to fall off the hi-idle cam.
Old Jan 16, 2006 | 09:51 PM
jrl1973vette
yeah mine will idle really high for a long time i almost am afraid to let it go sometimes becuse it seems like it is never going to kick down
Old Jan 16, 2006 | 11:33 PM
fl_rider's Avatar
fl_rider
The high idle is adjustable too...
Its hard to see but there is a screw on it for adjustment.
Old Jan 17, 2006 | 02:01 AM
Jclgodale3's Avatar
Jclgodale3
and should idle @ 12-1400 rpm's for warmup
Old Jan 17, 2006 | 09:19 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the high idle cam will reset itself when the car is warm and you step onthe gas....if yours is not doing this try cleaning the linkage and see it the choke setting is correct
Old Jan 17, 2006 | 09:34 AM
kb2fzq's Avatar
kb2fzq
In a few words..yes, kick it once and you should be at regular idle after warm-up....From The Great White North...upper upstate N.Y.
Old Jan 17, 2006 | 10:42 AM
Boofers's Avatar
Boofers
If you only have to 'kick it down' once (after the engine is warmed up) then its just your choke. If you find you are kicking it down at every stoplight it may be something else...
Sometimes what can happen on older carbs is they get worn in the primary throttle plate shaft holes in the carb base plate. The throttle plates end up being just slightly twisted so they don't close all the way UNLESS you hit the gas pedal and take your foot off real fast. This makes the plates move closed fast, with enough momentum to close all the way.
To verify this is the problem take your throttle return springs off and see how nicely the throttle plates close by hand. Compare with the springs back on. If your throttle plate shaft holes are worn the plates will 'bind' due to the pulling of the springs.
The most common fix for this is to have a carb repair guy install bushings in the baseplate to firm up the shaft.
corvettefaq qjet info links
To engine warm up
