Heater Core
Old Jan 17, 2006 | 09:57 PM
JustForFun's Avatar
JustForFun
Default Heater Core
Does the evap housing have to be removed to remove/install a heater core in an 81?
Old Jan 17, 2006 | 11:00 PM
MoneyPit's Avatar
MoneyPit
can't answer for an 81, but for a 69 it does not. On the 69 everything (practically) is done from inside the car once the hoses are disconnected. This is about a 1.5 case job, just because it is no fun, and the more liquored up you are the better.
Old Jan 18, 2006 | 03:32 AM
Solid LT1's Avatar
Solid LT1
Go from the passenger side, it's MUCH easier to get at from that side.
Old Jan 18, 2006 | 09:19 AM
jdp6000's Avatar
jdp6000
Yes it does. The core is in that box. I hope we are talking about the same thing. Its not that tough. it will take time. I have done it on an 82.
You need to remove the dash part that holds the glove box. The right side consol cover. The center cluster has to come out (don't miss the two screws that hold it to the consol plate)to get at the ducts. Once this is all out of the way you can see the box that contains the core.
Disconnect everything that attaches to the box (vac line, heater control etc).
There are either 2 screws or 3 screws visible from the inside that need to be undone. There is one screw on the upper passengerside firewall that you need to get at from the engine compartment. Most forget this one and break their box. I know the core box attaches to the box that contains the blower but can't remember if it was attached with screws. If this is the case you will see these. Its the one on on the firewall most miss.
Drain the coolant. Crawl under the car and detach the two hoses that go to the core. Some are on so tight they will not detach. If this is the case cut the hoses as close to the core connection as possible. Then cut the remaining rubber off the core...the core box will not come out with the rubber there, the holes in the firewall are too small.
Go back inside. It takes a GENTLE pulling,lifting and twisting motion to get the core box out. It does come out....a bit tight.
Open the box up and replace the core. Lube everything up. check for debri in the blower area...clean it out if you find any.
Install in the reverse. Should take 2 to 6 hours.
Jim
Old Jan 18, 2006 | 07:32 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I took the dash out of the '80...made it much easier to get to stuff...I didn't say it, but drain your water first..
Here's a write up with pics that might help...click here...
To Heater Core
