Power Steering Problems
Old Aug 6, 2001 | 03:37 AM
Ben Taylor's Avatar
Ben Taylor
Default Power Steering Problems
The power steering on my 81 was leaking like crazy so I got all 4 new hoses and a valve repair kit. I put all the stuff back together and I bleed the power steering by turning the wheels back and forth untill the fluid was clear with no bubbles, but now when I turn it with the engine on it trys to turn itself to the right and it kind of pops when changing directions. There are no leaks anywhere and I haven't moved the car yet, all my testing was done in park, but I don't see why it's doing this, where did I screw up?
Old Aug 6, 2001 | 06:03 AM
Dalannex's Avatar
Dalannex
Default Re: Power Steering Problems (Ben Taylor)
Did you balance the control valve? If not you need to. You can get directions for how to do it on Zip's web site.
Old Aug 6, 2001 | 10:19 AM
Jim Shea's Avatar
Jim Shea
Either your control valve is not balanced (as the previous thread indicated) or you have the control valve to assist cylinder hoses mixed up.
I just eMailed you the power steering hose routing instructions. It is possible that you have the two hoses at the control valve installed improperly.
JIML82@aol.com
Old Aug 6, 2001 | 02:44 PM
Ben Taylor's Avatar
Ben Taylor
Default Re: Power Steering Problems (Jim Shea)
I didn't balance the valve, thanks for the help guys.
Old Aug 6, 2001 | 05:02 PM
Michael Mustac's Avatar
Michael Mustac
Use the Chilton manuel and follow the directions to a tee. Take your time and you will see that as you turn the adjustment nut responce is not immediate!!! Be patient and find that "sweet-spot" that centers the wheels. You also need an alignment when you are done. Also be careful as to the position of the two hoses that exit your power steering pump. Make sure that they are turned away from your lower a-arm as the low presure hose, the one closest to it, will bind and eventualy slice it. Good luck!
Old Aug 6, 2001 | 07:42 PM
Steve Grodin's Avatar
Steve Grodin
Default Re: Power Steering Problems (Michael Mustac)
Alignment is not needed after changing out power steering control valve.
[Modified by Steve Grodin, 5:45 PM 8/6/2001]
Old Aug 7, 2001 | 12:01 PM
Jim Shea's Avatar
Jim Shea
Default Re: Power Steering Problems (Steve Grodin)
It is true that you don't have to realign your front end after changing your control valve. However, your steering wheel and steering gear may need to be centered if you do not screw the new control valve onto the relay rod the same number of turns as the original valve.
To Power Steering Problems
