power brake booster
Old Jan 19, 2006 | 01:12 PM
loUiSiAna van's Avatar
loUiSiAna van
Default power brake booster
What tool is needed to remove booster from a 74 vet. I looked under the dash, and it is tight. Thanks for your help.
Old Jan 19, 2006 | 01:23 PM
Empatho's Avatar
Empatho
It's one of my future projects
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
1 socket, 2 swivel joints, 3 extensions and a whole lot of patience.
Old Jan 19, 2006 | 02:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Boosters seldom fail. Are you sure your problems are the booster?
Old Jan 19, 2006 | 03:53 PM
worship79's Avatar
worship79
You forgot yoga skills
Taking the seat out makes it easier to reach the bolts, but bringing a pillow is not a bad idea.
Old Jan 19, 2006 | 03:56 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If it's a coupe, I'd recommend pulling the t-tops, too. You never know where your legs might end up.
Old Jan 19, 2006 | 04:00 PM
kona's Avatar
kona
A twelve y/o with small hands.
Kona
Old Jan 19, 2006 | 04:26 PM
loUiSiAna van
I'm sure it has a air leak when I hit the brake.
Old Jan 19, 2006 | 04:47 PM
itzfrank's Avatar
itzfrank
uhmm.. if ur brake feels like it has an air leak.. isn't that usually the mastercylinder and or brake lines? I thought it was ur brake booster if your pedal is too stiff... not the other way around.
Old Jan 19, 2006 | 04:54 PM
mrvette's Avatar
mrvette
OH, come on guys, I can have my stock brake booster out and in hand in 30 minits....easy....take out the seat....4 bolts...
drop the wheel....two 9/16 just behind dash, two 1/2 on the firewall...flop...1/2 dzn phillips screws and a few plugs and the speedo tach is yours....
then it's a clear shot to all 4 of the booster bolts....the clevis pin is the only reason to be upside down one bit...a 1 minits job....
guess I done it some few times over the last ten years....
GENE
Old Jan 19, 2006 | 05:30 PM
Ak. Mal's Avatar
Ak. Mal
Honestly, I don't understand why everyone claims this to be one of the hardest projects on a C3. I really had very little trouble changing mine. I removed the seat (as already suggested) and left room in the garage to leave the drivers door all the way open. I had the tops off before I started, and yes, there were times my feet were that high in the air. I wasn't joking about the swivels and extensions, it made my life much easier.
I think the hardest part for me was putting the clip back on the pin that goes through the clevis a pedal arm. For some reason that little bastard gave me fits. Plus, after laying upside down in the impaled crane position, I had a wicked pressure headache.
To power brake booster
