Vibration?????
Old Jan 19, 2006 | 07:51 PM
69shrk's Avatar
69shrk
Default Vibration?????
Took my 69 coupe out today and noticed a vibration @ 60+ mph only under power when i am at that speed and put in the clutch the vibration goes away the car is 350 350hp m21 trans any help much appreciated
Old Jan 19, 2006 | 08:17 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I usually start with the easy stuff...U joints would be my starting point..
Old Jan 19, 2006 | 08:34 PM
69shrk's Avatar
69shrk
thanks Avette4me ill start there
Old Jan 20, 2006 | 02:04 PM
spikezz4's Avatar
spikezz4
Default Vibration
Check your frame under each door for corrossion, and also the dogleg behind the doors before the half-shafts. I could put a small screwdriver through mine, so I had no rigidity or strength in the frame. Consequently, I'm rebuilding it. The frame was absolutely unsafe.
Spike
Old Jan 20, 2006 | 08:38 PM
69shrk's Avatar
69shrk
Spike:
The frame is solid thats the first thing I checked
To Vibration?????
