Help? Power Door Lock Accuator Bad
Old Jan 20, 2006 | 10:57 AM
Wtb80Vette's Avatar
Wtb80Vette
Default Help? Power Door Lock Accuator Bad
Anyone ever have to replace one of these on a 1979? I got the door panel off, power window motor cover off, I have spotted the accuator but it is not clear how it comes out of the door. It is somehow attached from inside the door and it is not clear how to remove it. I have an original shop manual but it does not cover the replacement/removal of the accutator - just the electrical aspects. The accuator still works a little but it drags real bad. The linkage is solid and works great - I just think the motor is tired. Help anyone? Thoughts??
Old Jan 20, 2006 | 01:47 PM
BerniesVette's Avatar
BerniesVette
I had mine out about a year ago. Did not need a book or anything for directions. Shine a light inside the door panel and also look at the door panel on the outside where they would be bolted. You should be able to figure out what bolt holds it to the door. The plunger has a rod that goes to linkage and has a curve in it that locks it to the linkage. Again, easy to disconnect and reattach. Are you sure it is the actuator and not the control that is bad?
bernie
Old Jan 20, 2006 | 01:51 PM
kona's Avatar
kona
There is an access plate which is held on by several screws. Then to remove the actuator you will need to drill out the rivets holding it in. Unplug the old one plug in the new and your done.
If you don't have a pop rivet gun you can use bolts to hold the new one in. These actuators are available at most local parts houses for around $30.
Kona
Old Jan 20, 2006 | 03:17 PM
BerniesVette
Mine were bolted in my '79. Seems the door panel already had nuts welded to the door panel; but its been a year.
Bernie
Old Jan 20, 2006 | 07:10 PM
1Z87L8's Avatar
1Z87L8
here is the interchange for the door locks if you should choose to get them from a u-pull it yard.
i got 4 for $12 from a 89 grand am as opposed to $50 a piece.
This part fits the following specific years and models:
1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987 1988 1989 1990 1991 1992 1993 1994 1995 1996 1997 1998 1999 2000 2001 2002 2003
Buick:
77-89 Century --------------- All Doors
90-96 Century --------------- LR, RR
77-86 Electra, Park Ave ----- All Doors
88-91 Reatta ---------------- LF, RF
77-85 Regal ----------------- All Doors
88-92 Regal ----------------- ALL Doors
77-91 Riviera --------------- LF, RF
82-89 Skyhawk --------------- All Doors
82-91 Skylark --------------- All Doors
82-91 Somerset -------------- All Doors
Cadillac:
82-88 Cimarron -------------- All Doors
77-85 Deville --------------- All Doors
77-91 Eldorado -------------- All Doors
77-85 Fleetwood, Brougham --- All Doors
86-90 (RWD) Fleetwood ------- All Doors
77-91 Seville --------------- All Doors
Chevrolet:
87-93 Beretta --------------- All Doors
82-92 Camaro, Z28, IROC-Z, RS, Berlinetta - All Doors
82-90 Caprice --------------- All Doors, Tailgate
82-90 Cavalier, Z24 --------- All Doors
82-90 Celebrity ------------- All Doors
82-85 Citation -------------- All Doors
87-93 Corsica --------------- All Doors
78-84 Corvette -------------- All Doors
82-85 El Camino ------------- All Doors
82-85 Impala ---------------- All Doors, Tailgate
90-93 Lumina APV ------------ LF, RF, RS Sliding Door
82-83 Malibu ---------------- All Doors
82-85 Monte Carlo ----------- All Doors
Chevrolet, GMC Truck
85-03 Astrovan -------------- LF, RF
85-95 Astrovan -------------- RS Sliding Door
96-98 Astrovan -------------- Back Swing Out Door(Tailgate)
78-87 Caballero ------------- Lf, RF
77-94 K5 Blazer, Jimmy (Full Size)-- LF, RF
77-02 C/K 10/1500 Pickup ---- All Doors (excluding 99-02 Silverado & Sierra)
77-02 20/2500 --------------- All Doors
77-02 30/3500 --------------- All Doors
78-91 G10/20/1500/2500/30/3500 Van -- LF, RF
85-95 G10/20/1500/2500/30/3500 Van -- Rear (Side Swing Out Door)
78-91 G30/3500 Van ---------- LF, RF
96 G30/3500 (exc Express) --- LF, RF
93-96 P30/3500 Van ---------- LF, RF
87 R/V 10/1500 Pickup ---------- LF, RF
87-89 R/V 20/2500 Pickup ------- LF, RF
87-91 R/V 30/3500 Pickup ------- LF, RF
83-94 S10/S15 Blazer -------- All Doors
82-93 S10/S15 Pickup -------- LF, RF
91-93 S15 Sonoma ------------ LF, RF
85-03 Safari Van -------------- LF, RF
85-95 Safari Van -------------- RS Sliding Door
96-98 Safari Van -------------- Back Swing Out Door(Tailgate)
77-99 Suburban -------------- All Doors (except rear barn door)
95-99 Tahoe ------------------- LF, RF
00 Tahoe (Classic Style) -- LF, RF
91 S15 Syclone -------------- LF, RF
91-93 S15 Typhoon ----------- LF, RF
92-99 Yukon ------------------- LF, RF
00 Yukon Denali ------------- LF, RF
Oldsmobile:
77-85 98 Regency ------------ All Doors
91-94 Bravada --------------- LF, RF
78-91 Calais, Cutlass Calais - All Doors
82-96 Ciera, Cutlass Ciera --- All Doors
77-90 Custom Cruiser --------- All Doors
82-90 Custom Cruiser --------- Tailgate
77-85 Cutlass Supreme, Cruiser - All Doors
88-89 (FWD) Cutlass Supreme, Cruiser - All Doors
90-92 Cutlass Supreme (2Dr) ---- LF, RF
77-90 Delta 88, 88 Royale ------ All Doors
82-88 Firenza ------------------ All Doors
82-84 Omega -------------------- All Doors
90-93 Silhouette --------------- LF, RF, RS Sliding Door
77-90 Toronado, Trofeo --------- All Doors
91 Toronado, Trofeo (w/metal motor) - LF, RF
77 Vista Cruiser --------------- All Doors
Pontiac:
82-91 6000 --------------------- All Doors
77-85 Bonneville --------------- All Doors
77-81 Catalina ----------------- All Doors
84-88 Fiero -------------------- All Doors
78-92 Firebird, Trans Am, Formula, T/A, Esprit - All Doors
78-80 Grand Am ---------------- All Doors
85-91 Grand Am ---------------- All Doors
77-81 Grand Lemans ------------ All Doors
77-85 Grand prix -------------- All Doors
88-89 Grand Prix -------------- All Doors
90-92 Grand Prix (2dr)--------- LF, RF
77-78 Grand Safari ------------ All Doors
82-86 J2000 ------------------- All Doors
77-81 Lemans ------------------ All Doors
83-86 Parisienne -------------- All Doors, Tailgate
80-84 Phoenix ----------------- All Doors
87-89 Safari S.W. ------------- All Doors, Tailgate
85-90 Sunbird ---------------- All Doors
90-93 Transport --------------- LF, RF, RS Sliding Door
Old Jan 20, 2006 | 07:11 PM
Gary79's Avatar
Gary79
try cleaning all the electrical contacts first, and see if you can clean the actuator rod also, mine had grease & a lot of dust on it. while i was at it & used a spray grease on all the pivot points. mine work better now, not 100%, and i have found that they work better when the car is running, getting a full shot of electricity.
To Help? Power Door Lock Accuator Bad
