'77 Vette---removing drive shaft???
Old Jan 20, 2006 | 10:42 PM
JTHVETTE's Avatar
JTHVETTE
Default '77 Vette---removing drive shaft???
I'm helping a friend work on his Vette. What is the best way to remove the drive shaft on the C3 Vettes with a auto tranny? It looks to be REAL tight fit.
Thanks,
JTHVETTE
Old Jan 20, 2006 | 10:48 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
its really not.....when you get down there it will be easier then you think.....make sure you mark the yoke and the driveshaft they are balanced together and need to go back in the same relationship to each other..
Old Jan 21, 2006 | 01:18 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
when i did mine on my 77, i had to undo the tail and then take off the front yoke then take the shaft out.. theres not a lot of room...
Old Jan 21, 2006 | 07:29 AM
Al77Vette's Avatar
Al77Vette
Oh Bob or anyone. I forgot to do mark the relationship between the driveshaft and rear diff. I do know the front from the back of the driveshaft. Can this be resolved with a little trial and error?
Old Jan 21, 2006 | 09:00 AM
bobs77vet's Avatar
bobs77vet
back end is not a problem....just the front end with the yoke
To '77 Vette---removing drive shaft???
