HELP body off checklist
anyone else...did i miss anything?
record number of shims on each body mount, use same nuber when you put back on.
remove the frame to body/bumper bolts/brackets, not sure if there are any on a 76, i have a 71.
when installing the top rear shock mount bolts be sure the nut is on the inside of frame, otherwise you you won't be able to remove the bolt once the body is back on.
take plenty of pictures for future reference.
Have Fun!
Good luck
REDWING's list
Here is a list of the things needed to be done to remove the body.
Remove:
From Rear;
1.) The rear bumpers and support rackets
2.) License plate bezel and exhaust bezels
3.) Valence panel
4.) Ground strap from antenna
5.) Gas tank ground and sending unit wire
From Front;
1.) Remove the hood
2.) Valence panel and air dam
3.) Unbolt nose support from frame (will stay with body)
4.) Starter wires
5.) Ground straps (more than one place)
6.) Carbon can vacuum line
7.) Oil pressure gage line from motor
8.) Throttle cable from motor
9.) Coil wires
10.) Heater hoses and A/C compressor from motor. I straped the compressor to the fender.
11.) Alternator wires and temperature sending unit wire
12.) Fan and shroud, transmission cooling lines, radiator hoses, and radiator .
13.) Unbolt master brake cylinder from power boster.
From Center;
1.) Parking brake cable and brackets from under seat area
2.) Shifter cable and down shift wire (automatic) and speedometer cable
3.) Battery ground strap from frame
4.) Rocker moldings
also: seatbelt cables, count shims for future refference.
anything else?????
pics anyone???
bought straps, where do they go??? doors on off???
If you are redoing your interior, now would be a good time to remove it to reduce weight, even if you just remove the seats.
http://www.corvetterepair.com/tech_tips.htm
MID YEAR BODY REMOVAL AND REINSTALLATION
Body Removal Checklist
1. Battery - Disconnect only
2. Steering Column - Disconnect and remove
3. Master Cylinder - Disconnect lines only
4. Clutch Rod pedal - Disconnect wire clip only
5. Back up light plug - Disconnect only
6. Acceleration rod and ground straps - Disconnect only
7. Oil pressure line, big and small block - Disconnect only
8. Engine Wires:
Temperature sending unit - Disconnect only
Coil wires + and - - Disconnect only
Brake warning wire, 1967 only - Disconnect only
Alternator wires - Disconnect only
9. Distributor Tachometer Drive Unit - Disconnect only
10. A-Frame dust covers - Remove from under A-arm
11. Hood - Remove from car
12. Shifter ball and T-Handle - Remove
13. Side pipe covers or rocker moldings - Remove
14. Front bumpers and braces - Remove
15. Starter wires - Disconnect and remove
16. Splash shields, large and small - Remove
17. License plate trim - Remove
18. Rear exhaust panel - Remove
19. Gas tank sending unit wires - Disconnect and remove
20. Antenna and ground strap - Disconnect and remove
21. Seat belt anchors, left, right and center - Disconnect and remove
22. Emergency brake cable - Disconnect
23. Body mount, rear access door covers - Remove
24. Ground strap, left front body mount - Remove
25. Radiator core support bolts, lower only - Remove
26. All body mounts - Remove
'63-'64 coupe - 10 bolts
'63-'64 roadster - 12 bolts
'65-'67 coupe - 8 bolts
'65-'67 roadster - 10 bolts
