Vacuum advance hookup
Old Jan 21, 2006 | 03:58 PM
ThereIsNoSpoon's Avatar
ThereIsNoSpoon
Default Vacuum advance hookup
I'm going to be installing a distributor with vacuum advance (my current dist does not have vacuum advance). I know that I want to hook it up to manifold vacuum, but my question is as follows. I have a manifold vacuum source on my carb (Holley 700cfm double pumper) that currently goes to the automatic transmission and also the electric choke. Is it okay to make another "T" off from this line and connect it to my distributor? I just want to make sure that it's not too much load for that source, or find out if there is something else I should do. Thanks for the help!
Old Jan 21, 2006 | 04:03 PM
redc3's Avatar
redc3
you should have more than one vac tube coming out of you carb. also you have a tapped hole in you manifold that you can use as a direct manifold vac source if you need to. its on the pass. side back runner of the manifold.
Old Jan 21, 2006 | 05:27 PM
ThereIsNoSpoon
As far as I can see the only manifold vacuum sources on my carb are the PCV and the one I described above. I have an air gap intake and I will look for the tapped hole tonight. Just to make sure I know what I'm looking for, should it be covered by a bolt? Do I need to buy an appropriate connector to be able to connect a vacuum hose to it? Thanks for the help, its much appreciated.
Old Jan 21, 2006 | 07:19 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Yeah, you'd have to get a barbed connector that would screw into the intake hole. Should be standard size & easy to find at the parts store.
Old Jan 21, 2006 | 08:47 PM
justkddn's Avatar
justkddn
i would make sure you dont have a port for ported vacuum (above the
throttle plate) as this will give you better idle quality
Old Jan 21, 2006 | 09:08 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by ThereIsNoSpoon
Is it okay to make another "T" off from this line and connect it to my distributor? :
yes Ts are ok....however you may want to check the vacuum at the end of the line to make sure it is adequate......
you mention a vacuum line to the choke??? perhaps thats the line that sucks in the warm air from the crossover....that will not work....do you have power brakes you could tap in to that line....but the line to the trans should work fine ....and you may have a ported spot on the carb....just experiment and see which is better ported or manifold and remember a higher idle does not means its running better.
Old Jan 21, 2006 | 10:58 PM
ThereIsNoSpoon
(1)The electric choke is hooked to the same vacuum line (manifold) that runs to the auto trans. The reason for this is that it draws fresh air into the choke housing which prevents the heating element from overheating. (2) Yes, I do have power brakes. The brake are on the same vacuum line that goes to the PCV. (3) Yes, I do have a ported spot on the carb; however, from reading this forum I believe I would be better off using manifold vacuum.
Does anybody know a part number for a vacuum connector that will screw into the manifold directly? It sounds like I shouldn't make anymore T's off of my current lines.
Old Jan 22, 2006 | 01:01 AM
justkddn's Avatar
justkddn
the vacuum line to the automatic choke goes through the manifold draws fresh air from the port on the rear of the carb highest on the back that is vented into the air cleaner.the vacuum source for the choke comes from inside the choke housing.hook the fresh air source to the choke puts vacuum on both sides of choke and there will not be any air flow.vacuum advance is best hooked to ported vacuum supply. hooking vacuum advance to manifold vacuum will give you a surge at idle from timing changing with engine vacuum,worse if you have a rad cam.vacuum advance is used to advance timing when you have high vacuum and retarding it with low vacuum (acceleration)
To Vacuum advance hookup
