Door Latch lubing
Old Jan 21, 2006 | 07:13 PM
79vetter's Avatar
79vetter
Default Door Latch lubing
I have taken the door latch off of one of the doors just because it looks so awful from outside. My goal is to have the power windows, door locks and handle all glide really easily.
The door latch is off and I have wire brushed externally as much as possible but the rotating pieces and springs are not as exposed. How do you get in there so that you can clean all of that up ? Or do most just replace the door latch entirely. I could just spray white lithium grease onto it and hope for the best..
Old Jan 21, 2006 | 10:37 PM
Sayfoo's Avatar
Sayfoo
Put it in a coffee can with some solvent and slosh it around for a while. Be careful with whatever solvent you use. Some are toxic and most are very flamiable. I use gasoline alot myself, but be carfull and use rubber gloves. Get a parts cleaning brush--usually about 2" stiff brisels about 1" in dia.
Old Jan 22, 2006 | 10:41 AM
stingr69's Avatar
stingr69
And then the spray lithium grease.
-Mark.
Old Jan 22, 2006 | 01:38 PM
chris75stingray's Avatar
chris75stingray
i did that with the door handle and it is amazing how much easier it moves.
To Door Latch lubing
