Another Suspension Question
Old Jan 21, 2006 | 11:02 PM
JustForFun's Avatar
JustForFun
Default Another Suspension Question
The cross bar for the lower control arms, Does it have a top and bottom, or both sides of it the same. I guess Im asking can it be installed upside down when attached to the cross member?
Old Jan 21, 2006 | 11:10 PM
72LS1Vette's Avatar
72LS1Vette
I posted the same question a month or so ago because the A.I.M drawing wasn't detailed enough. I installed one arm one way and the other with the bar flipped and took some pics. I don't know what year you have, but for a 1979 here is the way it should look:
Correct mounting
Incorrect mounting
The arm should sit flat against the frame at the front.
Rick B.
Old Jan 21, 2006 | 11:16 PM
JustForFun's Avatar
JustForFun
well #^%$&(^Q%$
i was HOPING that was not that case. Looks i get to remove one cross barr and turn it.
To Another Suspension Question
