Door spring replacement
Old Jan 22, 2006 | 10:53 AM
randyredleg's Avatar
randyredleg
Default Door spring replacement
I need to replace that S-shaped door spring. Is that special tool they advertise in the catalog really necessary?
Old Jan 22, 2006 | 10:58 AM
colorado1967's Avatar
colorado1967
I did mine with a regular small pry bar. Great directions on forum if you do a search.
Old Jan 22, 2006 | 11:07 AM
Bass's Avatar
Bass
I found it helpful, but a small pry bar seems like it would also do the job. A straight screwdriver- maybe not.
Old Jan 22, 2006 | 11:39 PM
Steve COSD's Avatar
Steve COSD
Hey Randy
I have the tool and I live in Escondido. You can borrow it if you want.
Send me an e-mail. Go to corvettesofsandiego.com and click on the box at the bottom of the front page.
Old Jan 23, 2006 | 12:52 AM
Z-man's Avatar
Z-man
Whatever you use, it has to have the bend in it. A regular screwdriver isn't beefy enough and is straight so it won't work. A brake adjuster might work. The springs have a good deal of tension, so it has to be strong enough to work against the tension without bending.
Aren't they only 5 bucks? I think it would be worth the aggrevation to get it and be done with the job. It only takes 4 minutes to install - 1 to install it and 3 to drink a beer afterwards.
Old Jan 23, 2006 | 09:20 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Make sure you put a towel or old tee shirt in the space between the door and fender. That way, when the spring falls it doesn't scratch the paint.
Old Jan 23, 2006 | 09:59 AM
HDIronman's Avatar
HDIronman
I use my distributor wrench, with a bend in it. Works great...!!!
To Door spring replacement
