Water Pumps
Old Jan 22, 2006 | 08:09 PM
8DVETNUT's Avatar
8DVETNUT
Default Water Pumps
What's the difference between a stage 1 and stage 2 water pump?
Old Jan 22, 2006 | 09:59 PM
Hitch's Avatar
Hitch
The stage 1 is just a OEM type replacement, the stage 2 is somewhat of an upgrade but not racer boy crap.. Here is the gouge from the Stewart site..
Stewart Stage 1 pumps use brand new, original equipment castings that are machined to our exacting standards. Stage 1 pumps are compatible with stock lines and brackets but are internally modified for performance and reliability! Recommended for stock, OEM, or mild performance applications.
Stewart Stage 2 water pumps are assembled using the exclusive 356-T6 heat - treated aluminum casting. These pumps include several significant performance modifications, compared to Stage 1 pumps, for maximum performance. Recommended for stock, OEM, or mild-moderate racing applications.
Old Jan 23, 2006 | 05:54 AM
8DVETNUT's Avatar
8DVETNUT
Thanks, Sounds like stage 2 is the way to go.
Old Jan 23, 2006 | 11:04 AM
jackson's Avatar
jackson
AFAIK ... other differences too ... but ... PRIMARY DIFFERENCE: Stage 1 is IRON ... Stage 2-up are ALUMINUM.
Old Jan 23, 2006 | 05:33 PM
UMFLEET's Avatar
UMFLEET
1st Gear
Default Water Pump Out
Ever hear of a stage 2 water pump going out at 26000 miles on a 2002 C-5 ??
Old Jan 23, 2006 | 10:19 PM
Hitch's Avatar
Hitch
It's what I'm running and quite a few others that I know.. Dave..
To Water Pumps
