A friend of mine is installing a 502 in his 71 Vette.He is wondering what,if any intake options he has.He wants to use the stock big block hood,not the L88.His 502 has oval port heads.Any suggestions??
Thanks!!
Edelbrock Torker II is very low & works w/ that hood.
Most people will tell you that they have been more than a little displeased with the Torker II on their rat motor. Being a single plane, it kills all of the low end throttle response.
If it were me, I would just give up and swap hoods, why would you want to spring for the bad boy 502 and then kill it with a low (no) performance manifold? It was for this reason that I went with a 496 with rect. port heads instead of a 502. I am using a LS6 vette intake so my hood will close.
I have heard that the Torker is not too bad on the bottom end. Besides, with a 502, you might do good to lose a litle down low and pick it up at the top. I would think a 502 would have plenty of bottom end torque. Might be worth a try, IMO.
While I cannot provide firsthand experience with this manifold, I can say that I spoke with several people when I was considering this intake. Most people said that the torker gave them an off-idle bog that they couldn't tune out. I think Zwede may have been one of the people that told me this, but I have heard the same report from others.
I suppose if that if the primary use of this vehicle was going to be strip instead of street, then giving up low end grunt is ok. But, if you want a real stop light to stop light door slammer I would stay away from this intake.
I think there is a difference between the Torker and Torker II. The Torker II is designed more for a street driven car and gives a bit more bottom end. I had one on a 454 street/strip car a few years back and there never seemed to be a lack of bottom end power. The car ran mid 11's with stock oval port smog heads. I would give it a try.
