Heat Riser Gasket on a '79
Old Jan 24, 2006 | 08:47 AM
MILO's Avatar
MILO
Default Heat Riser Gasket on a '79
Is there suppose to be one there or not? When I got the car all the emission stuff was gone. So I ordered a heat riser valve and it came with a gasket. Now it's leaking after 5 years and I'm trying to find a replacement gasket locally. But after searching and going to different stores nobody has a part number for it. The gasket would go in between the exhaust manifold and the heat riser and would be a flat gasket not the donut.
So is there or is there not a gasket? Thanks for the help.
Old Jan 24, 2006 | 08:59 AM
Crash80's Avatar
Crash80
When my heat riser gasket developed a leak way back when, I drove it to the local Midas and they had one and replaced it for me. I don't believe it is a hard gasket to come across.
Old Jan 24, 2006 | 09:03 AM
MILO's Avatar
MILO
I may have to resort to removing it and bringing it to a muffler place or bring it to a local part store and have them physically match it up. I can't imagine GM would use different gaskets for all their Blazers and Trucks run the same heat riser setup.
Old Jan 24, 2006 | 04:08 PM
Tom454's Avatar
Tom454
Assuming you have 3 studs/holes...
Measure the distance from center to center of 2 of the bolt holes.
If it's 2-11/16... the gasket should be for 2" exhaust... FelPro #60083.
If center to center is 3-1/16, its for 2.5" exhaust and the FelPro number is 60117.
These are not listed for 79... so if the distance is different , then never mind.
Bring the exhaust/heat riser with you to match it up at the store.
Old Jan 24, 2006 | 04:49 PM
chevylit's Avatar
chevylit
Went out to the shop and looked at My 79,and it does not appear to
have a gasket between the heat riser and manifold.This is a 15000
mile car and I wonder if they came originally without a gasket.
Old Jan 24, 2006 | 05:37 PM
vabeachvette's Avatar
vabeachvette
My 73 had one when i replaced the exhaust manifolds I replaced the heat riser gasket too, most auto parts stores have them in stock.
Old Jan 24, 2006 | 07:13 PM
BerniesVette's Avatar
BerniesVette
Get rid of the heat riser. If you were to install headers you wouldn't have one anyway. I don't have one on my '79 and it still doesn't take it that long to warm up without it. If it were to freeze closed it would cause problems anyway. Just a thought.
Bernie
Old May 8, 2020 | 02:57 PM
maytyler18's Avatar
maytyler18
2nd Gear
I found that my 79 used fel-pro gasket 9672 (replaces no. 2391901) This is the gasket between the heat riser and the manifold.
Old May 8, 2020 | 03:11 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Fel Pro pt# 60083
https://www.summitracing.com/parts/FEL-60083
Jebby
Old May 8, 2020 | 03:34 PM
speedreed8's Avatar
speedreed8
2006 ??
Old May 8, 2020 | 03:38 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by speedreed8
2006 ??
Yeah...and I responded too.....I hate the "related thread" deal.......it is never related to anything and brings up zombie threads from whenever.
Jebby
Old May 8, 2020 | 03:41 PM
speedreed8's Avatar
speedreed8
Jebby
I agree. Seems to be getting worse every week.
To Heat Riser Gasket on a '79
