I did it so it can be done, however let some of the experts tell us where to drill the hole because the location I chose did not allow the plug to seat very deep. In other words I chose my location poorly and now I can't remember where I put it. I do remember choosing the lowest spot to aid in getting the most fluid out. I also ground the taper off the tap after getting the threads started so I could run the big part of the tap into the threads. BTW I have heard that you can do a transfusion if you disconnect the hoses.
my ford expedition has a plug from the factory
Reason: point of info
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
ok i could see buying one with a drain plug in it....but the idea of drilling a hole in a sealed unit thats full of fluid that recirculates in my trans scares the hellout of me....seems like you could not control where the material that was drilled or tapped went. i wouldn't do it on mine
Bob- was thinking of a very small hole ...not like a oil pan drain plug, and using a small brass plug to seal it. Getting ready to put a Transgo kit in and they want all the fluid drained. I'm not about to pull the tranny (right now) to get the stuff out of the torque converter, so I thought about the small drain hole might be the answer. I don't have any of the elaborate flusing equipment so that's not an option.
As I said earlier, I did this to my converter. The only problem was I drilled in the middle portion as opposed to the proper area towards the mounting bolts. The metal is plenty thick.
i guess if you are set on doing this you could always go with what the book says and drill the hole by the mounting tabs using the 1/8" drill bit for the special rivet and assess the thickness of the metal at that spot....and then you have two options.....with this special rivet the longer stud/shaft portion of the rivet has a sealed end on it somehow so it won't leak
the damn things way a ton so it has to be thick somewhere
Ok for the record..drilled a 5/16 hole in the torque converter under the mounting plates..metal was only about 5/32 thick. Put an allen set screw in at first with sealer and didn't like the way it was going to (or not going to seal). Took the MIG welder and covered it and ground it down..feel better with that.
For those draining their fluid in the future, the torque converter still easily held 5 quarts of dirty fluid inside.
why drain it? you just have to remove the pan and valve body to install a transgo kit. our shop uses the flush equipment to get all the fluid including the fluid in the lines and radiator. most peolpe dont think about the extra fluid in the lines and radiator
Drianed it cause I didn't know if the fluid had ever been changed or not (5 quarts is a lot of old crap to leave in there) and didn't want to worry about it. Don't have any fancy flush stuff here and didn't want to pump fluid in a bucket..so this was a very easy solution.
