Considering an Electric Fan
Old Jan 24, 2006 | 06:19 PM
Rock'n Old's Avatar
Rock'n Old
Default Considering an Electric Fan
There is no fan-clutch on my -69.
So instead of buying a new clutch, I am considering an electric fan.
Will a 16" fan be the right size?
I am wondering about this one from Perma-Cool:
JEG's: # 771-19115
The prize is right ( $ 105), and it seems to move a lot of air: 2,950cfm with lightweight aluminum blades. (16")
Some opinions to this?
Suggestions?
(Scandinavia never get that hot.
We have two winters: One white, and one green! )
TnX . . . . . . . . . . . . . . . . . . . . .
Old Jan 24, 2006 | 07:08 PM
BerniesVette's Avatar
BerniesVette
Most of us in the U.S. use dual 11 or 12 inch fans, but we have higher temps than you. I would think the one you have found would do a good job. One guy on the forum was going to try a Volvo electric fan which is supposed to move a lot of air. You might be able to get those cheap where you are; used.
Bernie
Old Jan 24, 2006 | 07:17 PM
olouieo's Avatar
olouieo
If you have a small block it should do the job. I went with Spal SP231 — 16" HP Pull Type 2360 CFM. Its more expensive but it works. Temperature never goes above 180 even in the 90s.
Old Jan 24, 2006 | 07:19 PM
shafrs3's Avatar
shafrs3
I agree with Berniesvette, we use a dual 11" setup that's rated at 2750cfm that works well here, especially on the hard to cool big block cars.
Old Jan 24, 2006 | 07:41 PM
Swave Dave's Avatar
Swave Dave
In my 1970 Big block, im using twin fans with shroud from a 1990's LT1 Vette ; they move a tremendous amount of air . Am presently cranking out 560 h.p./600 tq. (gross) with no problem whatsover keeping the motor cooled to 180 f. Hope that helps.
Old Jan 25, 2006 | 07:07 AM
Rock'n Old's Avatar
Rock'n Old
I can see your points with dual fans.
But my wishlist now, is quite long, so I was hoping to get away with it
with a single big fan, for half the price.
Since I have a smallblock 350, I think I will give the single 16" a chance.
I also want to try it with a thermal switch on 180°.
Old Jan 25, 2006 | 08:25 AM
monza_man's Avatar
monza_man
Go to Dewitts.com They have everything and they've only make stuff for vettes! I went with the single 16" spal fan for my '69 350/350 and it works great!!
Old Jan 25, 2006 | 09:25 AM
SIXFOOTER's Avatar
SIXFOOTER
Thoughts on running a single or dual fan with stock Rad? Just Rip out the existing shroud and fan/clutch and add in the electric unit?
'81 stock auto in fla
Old Jan 25, 2006 | 10:02 AM
68vertible's Avatar
68vertible
Old Jan 25, 2006 | 11:40 AM
Z-man's Avatar
Z-man
I'm running a 2500 cfm single Flexalite fan that has the appearance of the one in olouieo's picture, and have no cooling problems. I've got a SB 406 and have the fan set to turn on at 195 and off at 180. Also, I have an aftermarket radiator that is new and larger than the stock. I think yours should work fine as long as the radiator is clean and in good shape.
Old Jan 25, 2006 | 11:46 AM
SIXFOOTER's Avatar
SIXFOOTER
Old Jan 25, 2006 | 01:08 PM
Razorhorn's Avatar
Razorhorn
JEG's: # 771-19115
Suggestions?
My opinion is that if you don't have cooling problems, don't switch. I have dual Spals and they are LOUD!!
Old Jan 25, 2006 | 01:11 PM
BerniesVette
I have two 12 inch fans I bought from a local hotrod shop and I can't hear them running!
Bernie
Old Jan 25, 2006 | 05:48 PM
The Money Pit's Avatar
The Money Pit
I run the 16" Permicool and have no problems keeping the temps down under 180-190 on hot days.I got to add that when I went to the 406 I had no choice to upgrade the radiator to the Griffen 31X19 you see here. The stock radiator would not keep up with the 500 hp for much more than a half hour. Now I can cruise all day,and no worries about the temps.
Old Jan 25, 2006 | 06:13 PM
Rock'n Old's Avatar
Rock'n Old
Default @Money Pit
That is the one that I have been looking at.
How is the fan, when it comes to noise??
Is that a temp feeler, in the radiator?
Old Jan 25, 2006 | 06:28 PM
MikeC's Avatar
MikeC
I run a 15 1/2" fan off of a Ford Windstar and it keeps my 10.5:1 383 cool with it mounted to a Griffin rad. I also have the smaller 13 1/2" fan from the same van that I'm going to switch for use as a puller. I got it all for $100 CA unfortunately there is some fab work for the mounts as the shorud will not fit in the vette.
Old Jan 25, 2006 | 06:51 PM
Gordonm's Avatar
Gordonm
I am running a single fan on a stock LT1 radiater with no problems. It kept the 350 cool hoping it will keep the 383 cool.
To Considering an Electric Fan
Old Jan 25, 2006 | 09:10 PM
shafrs3's Avatar
shafrs3
Try one of these on your Dual Spal setup and they won't run full blast unnecessarily. I really like this unit; it varies fan speed with engine temp.
http://www.jegs.com/webapp/wcs/store...chItemId=84109
Old Jan 25, 2006 | 11:10 PM
glen242's Avatar
glen242
Running that Perma-Cool fan on my '76. No problems. Noise is not a problem. Temp. sensor, on mine, is mounted in the thermostat housing. Using a Painless wiring set up.
Old Jan 26, 2006 | 06:17 PM
jerrylee's Avatar
jerrylee
hey guys...i'm thinking of switching from stock 2 an electric fan set-up for my big block.....but i have been told 2 stay stock...can i please have some input..thanx..Jerrylee///
