Stray Coil Wire MSD HEI?
Old Jan 24, 2006 | 10:03 PM
enkeivette's Avatar
enkeivette
Default Stray Coil Wire MSD HEI?
Take a look at this picture. There is a stray wire and also possibly a missing bolt on my brand new HEI. Where does the wire go?
Old Jan 24, 2006 | 10:09 PM
Perfomer's Avatar
Perfomer
Put the missing screw thru the hole in the wire and screw it into the empty hole on the left . Coil ground
Old Jan 24, 2006 | 11:43 PM
enkeivette's Avatar
enkeivette
So then there are supposed to be two black wires grounded to the coil on the top?
Old Jan 25, 2006 | 01:16 AM
68vertible's Avatar
68vertible
Yes, one goes to the connection, the other goes to the coil. They bond to the coil frame to provide a coil reference ground. So you have one wire from the connector socket to one corner of the coil and the coil ground to the other.
To Stray Coil Wire MSD HEI?
