Rear end question.....again
Old Jan 25, 2006 | 04:53 AM
kb2fzq's Avatar
kb2fzq
Default Rear end question.....again
Sorry, I know we've been here before...
P225/70R15...27.4 inch diameter?
At 60 MPH I'm seeing 2500 RPM in 3rd gear (auto)...the programs I can find on the internet are showing I have a 3.40 rear end...is that right?
Old Jan 25, 2006 | 06:43 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
That's what I find using an online calculator
Old Jan 25, 2006 | 06:51 AM
kb2fzq's Avatar
kb2fzq
OK..I think my "?" really is, in 1976, did Chevy offer a 3.40 rear end?
Old Jan 25, 2006 | 07:20 AM
chevylit's Avatar
chevylit
In 76 the following were offered: code OA-3:08, code OD and LR-3:36
code OB-3:55 and codeOC-3:70.
Old Jan 25, 2006 | 08:00 AM
kb2fzq's Avatar
kb2fzq
OK, GOOD!!...thank you chevylit, so considering that I may have the wheel diameter off by just a bit, and the calculator showed 3.40, I would assume the closest to that would be 3.36 gears....yes? I can't believe it would be a 3.55, that's .15 off and 3.36 is only .04 off, or considering the 60 mph/2500 rpm might be off one side or the other, would I be correct to say, being a stock rear end, that I'm running 3:36's...YES?
Old Jan 25, 2006 | 08:08 AM
chevylit's Avatar
chevylit
The codes are stamped (not cast) on the bottom of the rear end
housing.You could check to see what ratio You have for sure but I
think You are correct with the 3:36 number.
Old Jan 25, 2006 | 08:32 AM
kb2fzq's Avatar
kb2fzq
Yeah, that's what I'm thinking...once it warms up around here again, I'll be back under the car and I'll check the stamp, but it looks like from what you told me, being the 3:36's came in two different styles, it was probably what they put in most of the vettes back then, just a stock, standard rear end, for those that didn't care what was back there, just as long as they could buy a vette...
Very good...you've been very helpful, chevylit...thanks much!!
Bill
Old Jan 25, 2006 | 08:54 AM
kb2fzq's Avatar
kb2fzq
Chevylit?...one more question...do you know if which, OD 3:36 or LR 3:36, represents a posi rear end and do you know if the "stamp" on the rear end will show that information (OD or LR)??
Thanks...
Old Jan 25, 2006 | 09:05 AM
1970-Bronze's Avatar
1970-Bronze
You should also note that the actual tire height does not always match the calculation.
I have a set of 275/60/17 which should calculate to be 31" but when on the vehicle, the measured roll-out is only 30.25"
Old Jan 25, 2006 | 09:54 AM
tracdogg2's Avatar
tracdogg2
Corrected tire diameter is Radius x 2.
Mike
Old Jan 25, 2006 | 11:03 AM
chevylit's Avatar
chevylit
Thanks...
I think beginning in 71 all Corvette rear ends were positraction.
Old Jan 25, 2006 | 11:12 AM
jackson's Avatar
jackson
chevylit: Would you happen to have the axle codes for '71 handy?
Old Jan 25, 2006 | 11:18 AM
kb2fzq's Avatar
kb2fzq
COOL!...thanks man
Old Jan 25, 2006 | 11:19 AM
chevylit's Avatar
chevylit
AA-3:55 AB-3:70 AC-4:11 AD-4:56 AW-3:08 AX-3:36 LR-3:36
I believe these are correct.
Old Jan 25, 2006 | 11:26 AM
kb2fzq's Avatar
kb2fzq
Last one...I promise...
Just went out and measured the radius X 2= it's just a little over 27, like 27.1 inches...dropped it into the calc'r...came in at 3:36 right on the nose!!
COOL!!
Old Jan 25, 2006 | 11:27 AM
jackson's Avatar
jackson
thanks!
To Rear end question.....again
