Gluntly
Old Jan 25, 2006 | 07:21 AM
mdonohue@altergroup.'s Avatar
Default Vertex Mag question
I have a line on a Vertex Mag to go on a slightly modified 68 BB, any info on these ( dialed in the right way ) on the car right now is a
780 DP Holly, Comp cams 282S, Edelbrock, 4speed, 373posi ?
Starting, driveability, etc. Thanks in advance for ANY input.
Last edited by mdonohue@altergroup.; Jan 25, 2006 at 03:48 PM. Reason: Incomplete Title
Old Jan 25, 2006 | 05:30 PM
BigBlockk's Avatar
BigBlockk
So, you want to put a magneto on a mildly modified street engine, correct?
Why?
Is there something wrong with the ignition that is on it now?
BigBlockk
Later.....
Old Jan 26, 2006 | 07:20 AM
It has a stock ignition now except for a " Points Eliminator" MSD .
The mag I can get is in perfect condition, won't cost me a dime until after it's dialed in and installed , and only then after a month of driving and cruise nights and no problems it will cost me 80.00+ set up.
If not, we yank it out !
He's got one on a 40 Ford (BB) and lives by these things. " If set up right, it won't leave you stranded "
We go back a long way, and I trust him.
You sound/look skeptical about these units, have you ever tried one on the street ??
Old Jan 26, 2006 | 08:55 AM
BerniesVette's Avatar
BerniesVette
Magnitoes have been and still are used on small gas airplanes without any problems. Don't see why they couldn't be used on cars. Just a thought.
Bernie
Old Jan 26, 2006 | 09:29 AM
jimmygmartin's Avatar
jimmygmartin
I've been running a Vertex Mag since 1977 on my '68 small block Vette,and I like it. It isn't cheap to set up though, and the magnets need to be recharged after so many years of operation (I'm not sure of the time interval as my car has sat for long intervals while I raised my family and built our home). Also if you use an electric tach you need a converter box. The car always fires right up and runs like heck. The Mag will work fine on a stock or modifed engine as long as it is set up right. I send mine out for set up and servicing.
Old Jan 27, 2006 | 07:33 AM
Thanks Jimmy, you made my day !!
To Gluntly
