Rear monospring 330#?
So many choices for a rear monospring for my 72 sb. Help! Is the 330# spring (8" bolts) from VB&P a good unit? Want to improve the handling - I'm also adding QA1 shocks. I assume that the 300 would be soft and on the mushy side. In looking through corvettefaq I saw a paper on this conversion (not sure of the spring rating) and the rear end was lifted up over the rear tires. I don't want that to happen. Any input on the specifics is appreciated.
Originally Posted by shafrs3
I feel that for a nice handling street setup that's capable of taking on most road conditions, a soft spring coupled with large stiff sway bars and premium shocks is the hot setup.
I just sold my 330# spring yesterday to a local guy here on the forum. The 330 spring seems to be a good upgrade from the stock one. I had good luck with it along with the rear sway bar, which I might be selling also now that it does not fit with the 10 inch rims.
The 1 1/8 sway bar is for the front, right? What size bar for the rear? What coil spring rates are you using in the front? Lots of questions I know, but I'm thinking of swapping to mono leaf rear as well.
I have the 1 1/8 front bar and had the 3/4 inch rear bar. I had the 460 coils in front and am now running 550s in the front and I have on order a 400# rear spring and will run with no sway bar.
I like my 330.
