Shorter rear spring questions.
Try taking a broom handle, hold it is the very center with your fist. Now get a little lid to pull down on one end.
You are not strong enough to hold that small kid?? It is all about leverage and anything that holds in the center doesn't really hold much. It is a falcrum for something else.
1/2 shafts as linkage is a poor attempt. A 6 link is far superior.
did you do this mod on a stock ta (offsetting spring mount location)? hummm, what a great idea. Can you provide more details of how this was done? i also noticed in your picture that the swaybar mount has been relocated. can you fill me in on that too. are you using a stock swaybar, aftermarket or one you modified yourself? looking forward to your input.....thanks
Gordonm, Here is another pic...
Guys, I understand your point of introducing a moment arm into the equation, I feel that installing the spring bolt and have it pull at an angle also causes the top of that trailing arm to twist inwards compressing the hub/axle shaft assembly towards the diff. I’m merely substituting one force for another, and I think it’s probably a wash between the two. For me I like to see that spring bolt verticle or nearly so. If nothing else, the spring cushions function better, the tip of my composite spring isn't subjected to forces it wasn't designed to bear, therefore I feel it's a better solution. Thats my story and I'm sticking to it.
You have compensated for bolt inboard relocation...think the question revolves around whether it is necessary....I don't think so.....
Since adding my steel shortened 7 leaf,I have romped on it pretty good....no issues..and I'm not the first to fit a shortened steel spring without messing with mounting brackets....
Rich
Rick
Rick
Rich
Currently I have 295/50-15s on all 4 corners (don't ask me- a prior owner did it). 295s up front is quite rediculous as they rub the inner fender and sway bar depending upon which way the wheels turn. The 295s in the rear don't quite fill out the L88 style fender flares.
Okay: fronts decrease rears increase, check! I came to the conclusion that ZR-1 sized 275/40-17 fronts and 315/35-17 rears would be a great look and fit for my car. Practically everyone uses the A-mold wheels, so I thought the 1990 wheels or sawblades from 1991-1993 would be a different appearance from the norm.
If I have Dave Herlinger build me some offset trailing arms, what else do I need to make the 17" x 11" wheels fit in the rear? I'm eyeing the dual mount rear spring and the front transverse leaf conversion.
Currently I have a 360# single mount rear and 550# front coils installed but I've never gotten to drive the car with them. If I can get sufficient income by summertime, I'll sell my installed but never used springs and buy for the dual mount & transverse front setup. I'm a huge fan of adjustability/variations.
Pictures here: http://gcrall.miller-motorsports.com...oject+Corvette Nevermind the exhaust, the steel rear spring and the Bilstein shocks, they're all gone, as is the engine. Resto-modification is one expensive proposition.
