MSD or Crane HI-6
Old Aug 7, 2001 | 02:27 AM
LT1driver's Avatar
LT1driver
Default MSD or Crane HI-6
Ok, which one would you use on a small block with hot cam, headers, intake and holley carb. I foul plugs to easy so need some help. Problems with either one? :D
Old Aug 7, 2001 | 03:07 AM
71coupe's Avatar
71coupe
Default Re: MSD or Crane HI-6 (LT1driver)
I use an MSD 6T. It works well.
MSD's are used by more racers than anything else. Why re-invent the wheel?
:boxing
Old Aug 7, 2001 | 07:36 AM
Gordonm's Avatar
Gordonm
Default Re: MSD or Crane HI-6 (71coupe)
I have the Crane HI6 in mine. Very happy with it after 3 years. The reason I chose this is there are no chips for the rev limiter. It ahs rotary switches instead of the chips. It was a few dollars cheaper also.
Old Aug 7, 2001 | 10:33 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: MSD or Crane HI-6 (Gordonm)
I went with MSD because they have all the pieces. I also used their Distributor.
If I want an RPM activated switch, I know MSD makes one...
To MSD or Crane HI-6
