Need help w/lower steering column
Old Jan 27, 2006 | 10:26 AM
Dick72LT1's Avatar
Dick72LT1
Default Need help w/lower steering column
I have the steering box off, the rag joint off and I’ve removed the bearing adapter (cover?) and the wire retainer. I need help with how to remove the lower bearing and the spring. There’s nothing wrong with them, but I want to clean/paint or replace them before I re-install my engine. It looks like a pry job with a screw driver, but it’s not yielding to moderate persuasion. Any suggestions?
TIA, Dick
Old Jan 27, 2006 | 11:40 AM
ltlevil's Avatar
ltlevil
Do a search for a Jim Shea paper either here or at corvettefaq. I think you'll find everything you nees there.
ltlevil
Old Jan 27, 2006 | 04:50 PM
Jim Shea's Avatar
Jim Shea
Since the lower end of the steering column is exposed to the underhood and engine environment, I would suggest soaking the area with penetrating oil to get rid of as much rust as possible to ease disassembly. Here is a page that shows the parts. It is posted at Terry Rudy's new corvettefaq websight.
http://jimshea.corvettefaq.com/wp-co...InstrPage3.doc
I don't think that the lower column bearing is a sealed unit. Make sure that you regrease the bearing after spraying the area with penetrating oil.
Jim
Old Jan 27, 2006 | 05:50 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Removing the lower bearing, is it just a matter of pulling it off once the retaining ring and retaining clip are removed? I have been thinking of replacing this bearing since it is 36 years old.
Old Jan 28, 2006 | 12:49 PM
Eddie 70's Avatar
Eddie 70
Originally Posted by sly vette
With column out of car, remove rag joint flange. Then remove the pinch sleeve. Now remove the retaining clip from around the retainer, and remove the retainer, and the spring. You should now have access to the bearing and nylon and/or teflon bearing holder. Clean the shaft with emery cloth spray with some PB Blaster, and try to pry the bearing GENTLY up and off the shaft. This worked for me with my '69 column and with some patience, it should work for you also. I hope I didn't leave anything out, but if I did I'm sure someone on the site will chime in. At least I think my spelling and grammar are correct.
Just found this in another thread. Very cool. Is this bearing something I can find locally or is it just a vette catalog part?
Old Jan 28, 2006 | 06:05 PM
Jim Shea's Avatar
Jim Shea
The lower bearing is GM 7805700 and is still available through GM dealers or other Corvette suppliers.
Jim
Old Jan 29, 2006 | 01:42 AM
Atascadero_Kid's Avatar
Atascadero_Kid
The bearing is held in a plastic mounting ring that is pressed into the end of the column. Remove the outer metal circlip and the outer metal cover. You can then soak the bearing and mount with penetrating oil and just knock out the bearing and ring.
The bearing is cheap and available from the Usual Suspects, so replace it.
Old Jan 29, 2006 | 11:20 AM
Eddie 70's Avatar
Eddie 70
Ordered my bearing this morning. Should be another fun project this winter. So far I have been taking a beating working on my car this winter.
Old Jan 30, 2006 | 11:32 AM
Dick72LT1's Avatar
Dick72LT1
Thanks for all the help. I soaked mine then persuaded it bit and it popped loose. Nothing holding it other than a bit of rust.
Old Jan 30, 2006 | 07:34 PM
Eddie 70's Avatar
Eddie 70
Used a little sandpaper and cleaned the lower end of the column. Sprayed a little PB Blaster on the bearing and it worked out pretty good. That bearing was dry as a chip and every thing was full of dirt and gunk. No wonder it was making a squeeking noise. New bearing is supposed to be here tomorrow.
Old Feb 1, 2006 | 05:44 PM
Eddie 70's Avatar
Eddie 70
Got my new bearing today. It looks like it has a small amount of grease in it. I was thinking it should have some more grease in it. I have some wheel bearing grease out in the garage, is this acceptable to pack the bearing with. I also have some Mobil Grease I could use.
Old Feb 2, 2006 | 09:51 PM
Atascadero_Kid
You can use either, though it really isn't needed, remember, the bearing you took out is over 20 years old...
Old Feb 2, 2006 | 10:11 PM
Eddie 70's Avatar
Eddie 70
I cleaned the new bearing of its old grease and repacked it this evening with some high temp bearing grease. Should be good for another 36 years.
To Need help w/lower steering column
