smoke coming form the headers
Old Jan 27, 2006 | 06:43 PM
73'454folendore's Avatar
73'454folendore
Default smoke coming form the headers
I just replaced the starter and thought I was going to have to remove the headers to get it out. So I soaked the bolts with wd40. I ended up not having to remove the headers for clearance. After getting the car started I noticed alot of smoke coming from the area I soaked down. Is there anything to clean it off or should I just let it burn off. Last thing I need is to have a fire start off the exhaust. Thanks
Old Jan 27, 2006 | 06:47 PM
shafrs3's Avatar
shafrs3
If there's any oil left on the headers you can wash it off with a hose, then let the residue burn off.
Old Jan 27, 2006 | 07:05 PM
marshrat99's Avatar
marshrat99
while WD40 is flamable it will evaporate quickly as the headers heat up and be gone before the heaters get hot enough to ignite the WD.
Old Jan 27, 2006 | 09:41 PM
Sayfoo's Avatar
Sayfoo
If you're not worried about a possible stain, just let it burn off.
To smoke coming form the headers
