Speedo/Tach problem in '76
Old Aug 7, 2001 | 01:08 PM
ppinto's Avatar
ppinto
Default Speedo/Tach problem in '76
The tach has always been bouncy. I'm assuming it's a bad ground, though I've had the dash apart and checked all the connections - including the ones at the distributor. This usually happens when the engine gets hot - but could happen at any time. The tach will randomly go to 0, then bounce back up.
The speedo just started having a problem. The needle is bouncy at all speeds, and reads speeds that are slower than they should be.
Anybody have any ideas?
